Hesitation
Old Jul 18, 2005
Civic02playa's Avatar
Civic02playa is an unknown quantity at this point
Hesitation
Hey guys i've been running the tsi kit for awhile now i cant say i've been pleased but at the same time i cant say that i have been totally displeased.. but at the same time i have a pretty big problem... i have run into a few boost leaks unfortuneatly i know where they are they just arnt that easy to fix...however the reason i am writing is that everytime i put the pedal tot he floor and give it 100% throttle the car bogs down and goes nowhere...but if i give it 98% throttle it will get up and go...this is obviously a very big problem but when i had my tuner check it out he said "has to be a boost leak" now i cant see how this is valid but at the same time i cant discard it...any help would be great..(o and its not the tps trust me),,,,,thanks in advance
Old Jul 18, 2005
turboengnr's Avatar
DONT PANIC
try some tuning. If the WOT adjustment is set to too lean or too rich, it will make for a very unpleasant drive.
Old Jul 18, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I think you have something similar to this:
http://www.7thgencivic.com/forums/sh...ighlight=weird
Old Jul 18, 2005
2K1Civic17"Gabe's Avatar
WHen was the last time you were tuned? It also sounds like you could be way rich. If you arent tuned or its been a while, get it retuned. Its summertime now and you could use another one.....unless your in Hawaii since their weather doesnt change, lol.
winanthony94
Sep 25, 2015 09:05 AM
Skunkone
Sep 24, 2015 04:38 PM
NROD315
Sep 23, 2015 03:46 PM
2005seTO
Aug 30, 2015 10:32 PM
2005seTO
Aug 18, 2015 12:45 PM
