good head gasket
Old Jul 17, 2005
drunkenmagnum's Avatar
good head gasket
who makes a good head gasket for the d17? im going boosted on august 2nd and was wanting to replace mine. thanks
Old Jul 17, 2005
the honda nippon leakless is pretty good. I think some people use double layer to lower compression.
Old Jul 18, 2005
turboengnr's Avatar
DONT PANIC
i talked to the lead designer of SCE Gasket company two days ago. In a week or so, they will be taking my block and designing this gasket for the D17.
http://www.scegaskets.com/products/titan.html
This gasket is amazing. Do some research about it. You will find that you CANNOT*** blow one. I found out that their original prototype Titan gasket was on a built GSR motor that made over 800 whp.
They had a twin turbocharged small block chvy truck making 45 psi of boost and put down over 1600 hp.
They do diesel trucks that make over 80 psi of boost.
And the gasket for our car will be designed in the same way, and will be just as stong as all those listed above.
***im sure you can blow one, but it is doubtful
Old Jul 18, 2005
civic01vtec's Avatar
OEM is best
Old Jul 18, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
mike.. let me know, i will be one of the first to buy the hg if they ever produce it.
Old Jul 18, 2005
Logan3024's Avatar
Id rather replace the gasket than the engine.
Old Jul 18, 2005
Havok2k1's Avatar
Wicked Pissah Admin
I concur. If you are not 100% on top of your tune, there's no way you should run it. This applies to 95% of the people here.
For someone that knows their EMS inside and out and has a built motor, then this an option. (the other 5% with money to put into the motor)
Old Jul 18, 2005
Jeff's Avatar
Jeff is an unknown quantity at this point
How much is it going to cost you for them to make you the copper headgasket?
Old Jul 18, 2005
turboengnr's Avatar
DONT PANIC
you really think a gasket will save your engine? Then tell me, why did i break 3 pistons, but have the stock head gasket still fully intact?
And do you really think that the stock head gasket or the Nippon Leakless gasket will be able to sustain 400+ whp? 20 psi of boost daily and 30 at the track?
Old Jul 19, 2005
Havok2k1's Avatar
Wicked Pissah Admin
Not sure who you are talking to, but note that you OBVIOUSLY apply to the 5% that I spoke of.
And the reason you blew 3 pistons? Remember the fuel systems you've been using over the past few years?? I think it might have something to do with the 100+psi fuel spikes and what was it, 16lbs of boost?
Old Jul 19, 2005
i've seen 600-1000whp cars use OEM headgaskets
Old Jul 19, 2005
Havok2k1's Avatar
Wicked Pissah Admin
as have I
Old Jul 19, 2005
turboengnr's Avatar
DONT PANIC
not on a single cam honda i bet.
I have had a number of turbocharged hondas. I had 3 different turbo setups on my Crx alone. I went through 3 motors on that car as well. I never blew a head gasket. I always broke pistons.
Also another good thing about these gaskets is the fact that you can get thinner gaskets, or thicker gaskets. Mine are going to be .085" to help lower compression.
Having a stronger head gasket should only be used on a motor that has a requirement for it. If your motor is built correctly with strong enough components, it will have a tolerance for detonation. You wont break a piston from occasional detonation while tuning. But you can easily blow a stock head gasket. So if you have an extremely strong motor coupled with an extremely strong gasket, you have a better chance of driving home from a good tuning session.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
01civyv3
Jun 2, 2015 05:21 AM
zaboomafoozarg
May 30, 2015 09:21 AM
mrohitredd
18
May 14, 2015 07:35 PM
HondaHomer
May 14, 2015 12:24 PM
