tsi kit is gay to install..
Old Jul 16, 2005
d17lpower03's Avatar
d17lpower03 is an unknown quantity at this point
like i said on the title..its gay to install....the intake tubing dont fit..well actually nothing is fitted rite!! i had to grind downt eh exhaust manifold to make it fit in!!..i searched people..and i need soem help i didnt find much excxpet people saying they got the kit and they were happy with it...but over...im having problems putting the intake tubing in...wut did yall do about putting it in???? no clearance to put it in for me....any advice would help thanks everyone =D =D =D
Old Jul 16, 2005
TheSmuggler's Avatar
Everyone has had problems with the kit, it's not just you. Some people even had to make new piping.
Old Jul 16, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
The intake rubber pipe is a tight fit. It will work fine exept you should consider it as a tepm solution. Too restrictive at the place where it bends.
The little rubber elbow placed @ turbo inlet. lille connector pipe is a connection for the main intake hose.
1. rubber connector elbow placed at about 45' upwards and towards front of the car (it kinda has to "look" towards hood lock)
2. attach metal extention
3. Connect intake hose to " turbo" as the last step. Take it first from the battery side under the radiator hose (intake should bend and its elbow should look towards battery)
4. connect air filter with engine ventilation nipple
5. connect ventilation hose (diamtr isnt right) from filter with engine
manifold wont fit with out saving angle in the right top
intercooler pipes fit fine and eazy, undercarrige plastics and wheel arches to be trimmed, but bov has to be thight up from the left wheel arch
the kit may look hard to intall, you will think pieces dont fit together, but it is just because engine bay space is so tight. You have to try many different approaches to install each item. Installing TSI is a long and painfull process.
link for the TSI computer wiring:
http://www.7thgencivic.com/forums/sh...d.php?t=207055
link for the TSI computer explanation:
http://www.turbodiscounters.com/html/fuel.aspx
post your concerns in this forum and I will try to guide you through the install.
I'm trying to tune my car with this kit now.
Old Jul 18, 2005
2K1Civic17"Gabe's Avatar
good info. It all fits, unlike what some people say. He is completely right. Its just cuz we have a tight engine bay. If you installed any other kit, you would still have the same room to work with, and thats what takes so long.
Good luck, you will be happy once you have it installed. Took me a weekend with a couple friends. I could do it in about 5 or 6 hours now Id think by myself. Except the wiring would take another hour.
Old Jul 18, 2005
the 3 way oil pressure t fitting dont fit...how do u get it to fit????
Old Jul 18, 2005
exturbo6's Avatar
i will be reinstalling my tsi turbo kitthe first week of AUg. hope it works this time around.
Old Jul 18, 2005
best of luck to you!
What were your problems before? I hope it all works out for ya, I am extremely happy with my kit! Car drives very nice, and its much quicker than before. 10psi seems so slow now though. I need about 15 to keep me happy...for a little while.
Old Jul 18, 2005
exturbo6's Avatar
Well Everything Was Fine Until I Installed The Kit And Then When I Ungraded To E-manage And All 3 Harnesses And Senor, It Wouldnt Hold Any Settings. Car Had A Few Fuses Blow. Ill Write More, Im Getting Out Of Work. Sorry About The Caps.
Old Jul 18, 2005
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
Talking tsi kit with 2 extra injectors and interface block
hey i just bought my tsi kit and Organic exedy clutch kit and act flywheel, and hks turbo timer. are you guys running a stock engine, and if not what upgrades were added. Also, can anyone email me the installation manual, mine didnt come with one. And please tell what were the hardest parts of the install and what can I do to make it go quicker.
Old Jul 18, 2005
This one is difficult, I had (have) same problem.
I think it might bite me in the azz later, but this what I did:
I was vary careful and slow...just screw the oil "T" into the engine block, I think I damaged threads in the eng.block, but so far it holds...
Old Jul 18, 2005
yeah, do what he said. Thats how I did it, but I didnt damage the threads. Mine fit perfect.
My car kept blowing fuses the other day when I first drove my car after the long long long wait. Its because there was one area I soldered a wire and forgot to put electrical tape on. It blew about 3 fuses, than I looked for a prob. I was moving wires around until the fuse would blow, than I knew where to look/fix. It was my boost or a/f gauge.
For making the car go quicker, just get a new intake. It will spool faster/louder. Not that it isnt loud as hell anyways. Just start working on internals so you can turn up the boost.
I am running 10psi on stock internals. Not a single upgrade other than the exedy organic, which I LOVE! very close to stock feel, and grips so much faster than stock.
If I knew where my installation manual was, I would e-mail you a copy, but I dont have it. Sorry. It couldbe at my moms house, but I moved out of there recently. When I go back, maybe tonight, I will look for them.
Peace
Old Jul 18, 2005
jbrown59's Avatar
CIVIC USER
Did you install the clutch yourself. I got the same one with an act flywheel from streetlevelperformance and I found the diy for clutch kit install in one of these forums and Im questioning if I should do it, with the help of some of my skilled friends. And how much did it cost if you got someone else to do it for you???? THanks Bump
Old Jul 18, 2005
eye_see_you's Avatar
let the devil out
well some of had issues.. I was a lucky one that did not.. but it may also depend on where you got the kit from. Sucks to hear your having so much of a problem but it is a tigt engine bay
Old Jul 18, 2005
i have a problem with my clutch now...when i press on teh cluth when i went into my car..it drops down and stays down ...my friend and i try to put some brak fluid and pumping it...and trying to fix it...no results..wut do u guys know wut it is??? or wut hte problem is?? thanks...
Old Jul 18, 2005
Sonds like cluch sylinder went out..coulde be the slave ove.
Easy fix (on my 240sx), part is cheap.
prepare about $100 for everything (part, labor, clutch bleed) to be done by a mechanic
Old Jul 19, 2005
howd u tune your icu??? can u show me how u did yourz??....acura 1.7l..u think u can give m your cell so i can talk to u over the phone clearly about the icu tune?? thanks
Old Jul 19, 2005
I wish I had my ecu tuned, I just installed the kit last week and struggling with idle (engine stalls at idle when warm)..
Well at this point I cant help you with your ECU
You might want to visit this forum first:
http://www.7thgencivic.com/forums/sh...ighlight=weird
Old Jul 19, 2005
yeah, check the clutch slave. Its to the left of the headers/turbo manifold. Connects to the shift fork. There is a rubber boot on the tranny that covers the shift fork,a nd the clutch slave presses into there. It has a line, that goes out of it, and near the battery. It connects to the same part as where the battery is grounded. FOllow that line, and youll find the slave.
If its busted, get a new one. only 2 bolts to replace it. Than you have to bleed it, and bleed it, and bleed it. A pump was the only way we could get the pressure back. Bleeding and pumping the pedal did NOT work for me, but everybody else apparently it did
Also check your Master Cylinder. more than likely, if its busted, it will be leaking brake fluid near your pedal, INSIDE the car. We have to pump about 10 bottles worth of fluid to get it bled correctly. We only used 2 bottles, but kept flushing the same through til no more bubbles were there.
Good luck!
Old Jul 19, 2005
on the black box..where do the 4 BROWN wires connect to???? =D
Old Jul 19, 2005
U need to use only the 1st one, I believe its socket #2
Then you connect it to the black wire on your injector (2 injector wires go to 1 brown wire)
red wires from inj goes to constant +12V
Old Jul 19, 2005
civic01vtec's Avatar
lol.....turbo kits are no joke
I wish they were all just "bolt on"
Old Jul 19, 2005
wut do i do with the other 3 brown wires????=D
Old Jul 19, 2005
just leave them, isolate them from everything else
Old Jul 19, 2005
Right,
just like SF - you pay, and they "they bolted"...
Old Jul 20, 2005
thanks for helping me out 1.7 El...now last question..i was wondeirng..how didi u set your maxboost??? wut settings did u use??? thanks =D
Old Jul 20, 2005
You hit Function to go through the settings. After EACH setting, hit OK to save them. It will go back to the main screen, and hit function again to scroll through and get to the next settings
If you want some rich settings, which I am running they are
rpm - whatever, this doesnt work, just leave it stock
OK
del - 40sec (how long for your turbo timer to stay on)
OK
0psi-14.0ms
1psi-16.0ms
2psi-18.0ms
3psi-20.0ms
4psi-22.0ms
5psi-24.0ms
6psi-26.0ms
7psi-28.0ms
8psi-30.0ms
9psi-32.0ms
10psi-34.0ms
11psi-36.0ms
OK
RPM (most people DONT use this, I do to help with boost lag/running lean not before boost ~-5hg~ to ~0hg~) I only set up to 4500rpms
1500-1.2ms
2000-1.6ms
2500-2.0ms
3000-2.4ms
3500-2.8ms
4000-3.2ms
4500-3.6ms
OK
Adjust Rate-63%
OK
Max Boost-8psi (this doesnt work for ****, whatever you want to set it to)
OK
hg-08 acyc-4.0ms
OK
The hg setting for the last part^^, helps with smoothing out boost or making it more agressive. If I set it to hg - 11, my car picks up much more, and its much better for track/race. hg - 09 works good for me in the winter for normal daily driving. Right now its 116 out, and I have it set for hg - 08.
So you will need to mess with that, and the fuel. You will run rich off these settings. No matter where you live you should be rich. My settings are way above everybody elses, but I needed these for the proper a/f. So I would get tuned ASAP! Dont drive far untuned, or unhook a charge pipe until you get tuned.
Old Jul 20, 2005
If you dont hit OK after each setting, it will/can reset on you while your driving. Mine resets anyways cuz its a POS. I am the only one with this prob though. Other than one person with the eManage who cant save his settings either.
Old Jul 20, 2005
when i press down on the accelerator..at when it is about to hit turbo...the rpm stops at 4000 rpm and my car dont go any faster....but hwen i let go of the gas a lil..then it goes full rpm....wut do i do????
Old Jul 21, 2005
Your running too rich it sounds. I would take fuel out. probably a lot. Start with settings around
0psi-6.0ms
1psi-7.0ms
2psi-8.0ms
3psi-9.0ms
4psi-10.0ms
and so on......
You really need the car tuned professionally. These settings may get you running decent, eventually when you find some good ones, but you dont know how lean or rich you will be running
You will still probably be a little rich. Where are you located, how hot is it outside? What altitude?
A boost controller is a nice thing to have as well. I have the Greddy Profec-b. It works awesome, and learns how you drive. So as you shift, it helps to make it a lot smoother for your driving habits, plus smoother acceleration, helps with boost spike, and boost lag, and easier acceleration
Old Jul 21, 2005
0psi-6.0ms
1psi-7.0ms
2psi-8.0ms
3psi-9.0ms
4psi-10.0ms
and so on......
Hey,
I think I'm at the end of chain with my idle issue, I will test my theory today after work and let you know!
If it works out I will be able to "play" with settings later on.
I agree now, TSI is GAY to install.
My install review: TSI kit comes complete with all parts and hardware, but be prepared to spent exxxxtra time on getting parts working together.
