Need for an intercooler with low boost?
Old Jul 14, 2005
Syke Fu's Avatar
Syke Fu will become famous soon enough
Thinking of boosting the civic, but need some info here first. If i do boost the civic, i'm thinking of starting it off with low boost ( 4-5 psi) just to get the engine used to turbo. Now the question is, do i really need an intercooler or not? I know it has advantages, but is it really needed on low boost applications? Thanks for any info.
Old Jul 14, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Anything above 5psi a FMC is needed to reduce det. Ide say if you are running 5psi with out a FMC then make sure its tuned.
Old Jul 14, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Greddy likes to make "basic" turbo kits w/o intercooler. They usualy start with 5-6 psi on a given engine w/o FMIC. So I think 5psi with good tuning and in mild climate shoud do it.
Old Jul 15, 2005
Alex1's Avatar
atleast use a DSM sidemount, its only 25 dollars
Old Jul 15, 2005
HyaBoosta's Avatar
since you live in TX and it gets pretty hot out I say get the IC and play it safe. It's alot easier to pay the 250 for a johnny racecar IC then to have to buy a new engine.
Old Jul 15, 2005
Syke Fu's Avatar
I definitely will be running a fuel management unit and tuning is a must. I may consider the side mount intercooler option as well. Thanks for the info.
Old Jul 16, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Dude, just get the intercooler, it is definitely worth it. An intercooler is part of a well designed turbo set up, it is 101. Tuning is always a must, but with out an intercooler, very good tuning is must, it opens the door for more problems, and with a turbo you will not want any more problems, especially one that could be solved by just buying an intercooler. You might as well spend the extra money to do it right, so just get a FMIC.
CraigW
Aug 18, 2015 07:06 AM
JDMnoob
Aug 2, 2015 02:38 PM
alxz310
Jul 30, 2015 12:18 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
