What do i do about this?
Old Jul 7, 2005
Michalo187's Avatar
Abortion Survivor
Ok so last friday i had my car tuned it then broke down and i fixed it sunday. Sunday as i was driving my check engine light came on after i raced. So i was like o **** and then i felt it in third like something was holding me back so i didn't know wtf. Yesterday i finally checked it with the obd 2 scanner and it says Fuel Cell too rich that pissed me off because they tuned my car and its still too rich he said he left it rich in high end but i don't think it should be that rich should it?
Old Jul 7, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
What was the A/F ratio when you dynoed? Do you have a MIL? When i had the SAFC i always had the CEL. It was because i was too rich at idle and cruising speed.
Old Jul 7, 2005
Michalo187's Avatar
Abortion Survivor
O ok thats maybe why the guy told me he was making it rich but in high end but i think it may be at idle because the car sometimes is a bitch to start and at idle it like wants to bog but then catches back does that cell make it run in limp mode or anything because if it doesn't then i wont worry
Old Jul 7, 2005
SODJAZERO's Avatar
Old Jul 7, 2005
Michalo187's Avatar
Abortion Survivor
^^^^^^ You just confused me i don't know where that is but i think i need to fix the dam idle i am tired of looking like a retard when i start my car and its hard to start everyone just stares like yeah the car looks nice but the engine sucks hahahaha can you explain better for me thanks
Old Jul 7, 2005
SODJAZERO's Avatar
Sorry man, i had to retract that prev statement. I thought you used the SAFC. I think your best bet is to get it back on the dyno and see whats happening, or have a mechanic look at it.
Old Jul 7, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
I said have the shop re-tune it (I don't think they did a really good job on it). If they charge u, they them to **** off and go to another shop.
Old Jul 7, 2005
turboengnr's Avatar
DONT PANIC
just because the ECU says its too rich, doesnt mean that it actually is. The Fuel system too rich code simply means that the fuel trims are outside of their compensation range (+- 20%). When it gets outside this range, the computer throws this code.
Have the car tuned for fuel trims. They will need a live-feed scanner, and will have to tune the car at all RPM ranges, under all loads. Then they will be able to have the fuel trims within their acceptable ranges.
Old Jul 7, 2005
Michalo187's Avatar
Abortion Survivor
It runs nice the only bad thing is idle and starting up the car thats what sucks other than that i can't complain
Old Jul 7, 2005
2K1Civic17"Gabe's Avatar
damn, that sucks. My car runs rich at idle as well. It has the stock injectors set stock at idle as well. Even for normal stock driving conditions they are not altered. I have the 2 extra injectors that get controlled. But my car still runs very rich at idle. I can smell the gas strongly. My car still gets 300+miles per tank though, lol.
Old Jul 7, 2005
Michalo187's Avatar
Abortion Survivor
do you have trouble starting the car?
Old Jul 7, 2005
nope, it starts on the second or 3rd crank. It starts up nicer than ever for some reason? The idle does fluctuate between 600 and 1500 rpms though. But only when I come to a stop or step on the gas, idle is fine when I start it up.
Old Jul 7, 2005
civic01vtec's Avatar
did they use the injector correction factor ?
Old Jul 7, 2005
Michalo187's Avatar
Abortion Survivor
yeah they did
Old Jul 8, 2005
eye_see_you's Avatar
let the devil out
try tuning with a wideband o2 sensor instead and you might have better luck
Old Jul 8, 2005
Michalo187's Avatar
Abortion Survivor
The did use a wideband o2 sensor
Old Jul 8, 2005
yeah, I dont think anybody in AZ that tunes on a dyno, doesnt use a wideband. I have never run across anything other than wideband in AZ. Other states must have some crappy tuners/shops, lol.
If I was you, I would drive your car nicely under very little boost, until it gets back to the 90s and lower.
I should have my car back tonight or tomorrow. Dudes a tweaker thats fixing it. I talked to him last night around 11 and he said he was gonna be working on it hardcore either last night or today. He wont leave my car sitting around his house like others he tweaks on though, lol. Hes my sons grandfather, so hell get it done quick Im hoping. He said he should have it back to me today or tomorrow. He can change a honda clutch in about 6 hours, and he only has to fix my shift fork. I musta put it on there fudged. It popped off when I touched it, so I couldnt see how it went together. I thought I put it all back right, it moved nicely, had good clearance, but I guess not enough room to travel. Im hoping my car gets back this weekend. At least for the Hooters meet with the car club.
Old Jul 8, 2005
Michalo187's Avatar
Abortion Survivor
^^^^ Thats cool i am leaving sunday for California but once i get back i am doing the head swap and crower cam valvespring retainer kit and aem cam gear i still also have my motor mounts laying around need time to install those dam things
