Oil Feed fitting from where?
Old Jun 27, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
Hey guys I have a small problem the turbo kit is in, the only problem I have is the fitting I bought for the oil feed to pressure sender line is too big...where did you guys buy your fitting from? Let me know...thanks guys!
Old Jun 27, 2005
civic01vtec's Avatar
I acutally have a **** load of brass fittings laying around that i used to piece mine together.
Do you know what size that u acutally need ???
Old Jun 27, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
What kind of fitting are you looking for. I know lots of places to get various assorted types.
Old Jun 28, 2005
Hwoody77's Avatar
Not too sure, that's why I'm asking...anyone know?
Old Jun 28, 2005
Jap-Euro Fusion
If you undo the pressure sensor fitting, you need a 1/8x28 BSPT fitting. Its best to buy a 1/8 BSPT to NPT adapter fitting from Mcmaster carr (about $5). Then you can use standard 1/8" NPT fittings and -4 AN lines available anywhere... summit, Jegs, local.....
Old Jun 28, 2005
andyman97's Avatar
Turbo Guru
Call stan at www.fast-turbo.com. He has all the parts you need. You may want to make sure your feed line isn't bigger than a -3AN, also.
RIPSAW
Nov 6, 2015 04:36 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
Vaguexo
Jun 13, 2015 04:11 AM
leon1
Apr 28, 2015 07:32 PM
BreezeNine
Apr 14, 2015 05:41 PM
