car shut off !!!
Old Jun 23, 2005
mxcivic's Avatar
mxcivic is an unknown quantity at this point
car shut off !!!
When i floor it, and then i brake the car justd shut off why is that ?
Old Jun 23, 2005
HyaBoosta's Avatar
Might be running too rich. could be dumping too much fuel and then when the car stops, it bogs down
Old Jun 23, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
any cels?
Old Jun 23, 2005
mxcivic's Avatar
no cels?
Old Jun 23, 2005
Michalo187's Avatar
Abortion Survivor
Only when you brake it does this? What about putting in the clutch?
Old Jun 23, 2005
mxcivic's Avatar
yep and putting in the clutch.
Old Jun 23, 2005
Michalo187's Avatar
Abortion Survivor
Maybe your battery is not holding a charge do you have a stereo system?
Old Jun 23, 2005
mxcivic's Avatar
nop i only have a pioneer dvd and i have a optima red battery
Old Jun 23, 2005
Michalo187's Avatar
Abortion Survivor
Its just cause your rich then what about your spark plugs did you check them out?
Old Jun 23, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Same happened to me when I was racing last week. I have nitrous though. I let off the gas at the end of run and put it in neutral simultaneously and my car shut down. It was sorta scary going like 90 with no PS or power brakes. Pulled over at the end of the track got out and made sure I didn't blow up anything like a HG or something and everything was fine. Got back in and it started right back up with no CEL or anything.
Old Jun 23, 2005
Michalo187's Avatar
Abortion Survivor
I think it has to do with your alternators because when you have the clutch in i dont think the alternator is charging up your car so it dies if you pop the clutch out i bet it starts right up because that happens to me but i have a huge system once i got a optima yellow top and a h.o. alternator its good to go
Old Jun 23, 2005
mxcivic's Avatar
yup michalo, i push the clutch and the car die, and i pop it then the car cames again ..... im going to check that thanks ...
Old Jun 23, 2005
turboengnr's Avatar
DONT PANIC
do you have alcohol injection?
Old Jun 23, 2005
Michalo187's Avatar
Abortion Survivor
^^ Just out of curiosity why do you ask this?
Old Jun 23, 2005
turboengnr's Avatar
DONT PANIC
if you are running a boost activated alcohol injection system, and you reference it from an intercooler pipe, you have a problem.
When alcohol injection is referenced from an intercoler pipe, it can see boost and activate when it is not needed. This is mainly when you are on the throttle, then you suddenty let off. This creates a spike in pressure in the intercooler pipe (hence the reason you need a BOV), and this spike activates the pressure switch that runs the alcohol injection. When this happens, it injects alcohol into the throttle body. This extra fuel causes the car to bog (since there is not enough air) and the car dies.
You can fix this by referencing the alcohol injection off of manifold pressure instead of charge pipe pressure.
Old Jun 23, 2005
Michalo187's Avatar
Abortion Survivor
I did not know that thanks for the info
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
TropiKalCiviC
Nov 8, 2001 10:13 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
