Those with Aeromotive Boost referencing FPR...
Old Jun 21, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
Ok, I got it at 45 PSI at idle without the vacuum line hooked up, when I hook up the l;ine it drops to 38 PSI...is this normal?
Old Jun 21, 2005
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Yes.
Boost will increase fuel pressure, vacuum will decrease fuel pressure on a 1:1 ratio with that regulator.
Old Jun 21, 2005
Hwoody77's Avatar
But isn't it supposed to be at 45 PSI at idle?
Old Jun 21, 2005
tfnaaf's Avatar
BLDNPSI Mod
there abouts yes, so you need to adjust the pressure with it hooked up so its as i recall spec is around 45psi. The stock pressure regulator in the tank has no vacuum source at all to reference. so it should be 45 with the vacuum hooked up. Other wise you could possibly run lean at idle and under modest load. Up to a week a go I had no vacuum line hooked up at all for the past 4? months since i did the return conversion. But now that im almost done with the install i will hook it up and have to readjust pressure at idle to reflect the vacuum source.
Old Jun 23, 2005
HyaBoosta's Avatar
I would loose that and just get an emenage. I had one with my setup and it made less power tuned then just my emenage
Old Jun 23, 2005
tfnaaf's Avatar
BLDNPSI Mod
I THINK you may be thinking of the FMU regulators. What he is talking about is the aeromotive FPR that senses vacuum/boost and when it goes into boost it raises the fuel pressure 1 psi per 1 psi of boost
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
