Must Read, How Does A Missing Link Work?
Old Jun 12, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Ok, I need a detailed diagram of how a missing link works. For about a few weeks ive been having this problem of my car cutting off and on" at low rpms or idle.This would be randomly below 3k rpm or at idle in VACUM. Then i came to a point were i singled out the problem. For example, ill drive 25-30mph, drop the car in 5th, at this point the rpms would be below 1500 rpms. Then i stepped on the gas, of corse the car reacted really slow and rite as the needle came to 1500 it would "cut off and on" , just a real quick flicker off and on. This told me it was a map sensor problem. Up to this point i have had no CEL, and the only time it would show is when the car would do a quick flick off and on then i would see the CEL but it would go away soon as the car came back on, wich is less than like half a second. I have tryed trouble shooting in many ways. To make a long story short i figured out what the problem was. I removed that little filter on my missing link and the car idles like ****, but it doesnt "cut off and on" randomely any more. I drove it out like normal, droped the car in 5th, rpms below 1500, and jammed on the gas, now it sputtered and acted slugish, wich is what i expected. But it didnt cut out at all. I road the rpms all the way to 5k in boost with NO PROBLEM. When cruising i would also have this problem below 3k rpm. With out that little filter in the ML the car runs shitty. So I pulled it out and im in the process of cleaning it with soap and water. My question is does any one have a detailed diagram of how this missing link works? I want to better under stand how it works. I know it just "hides boost from the MAP", but i like knowing exactly how thinks work so i can diagnose problems when they come about. I hope this helps you turbo guys out. I was about to take this dam thing to the dealer ship and have them look for a electrical problem, needless to say im glad i didnt. I know some one recently posted a thread on the little filter in the ML, are there any replacements for it? BTW RiceburnrEX is very helpful when it comes to trouble shooting 7th gen issues, thanks man!
Old Jun 12, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I wonder this topic myself. I never could get mine to work for more than a day or two, especially if it was cold outside. If you have an emanage you could use the boost cut limit instead though. I hope someone posts this info up.
Old Jun 12, 2005
SODJAZERO's Avatar
So i cleaned the filter, and put it back in, and the problem came back. I think the filter is just too dirty and its giving the map sensor crappy readings...
Old Jun 12, 2005
SODJAZERO's Avatar
ok, i just removed that little filter and taped it up and my car works fine now..... So is the little filter nessesary?
Old Jun 12, 2005
andyman97's Avatar
Turbo Guru
Well, if you run fine without it, I'd say no, it isn't necessary. That's why I ran a string of 3 check valves instead of the ML. It's cheaper and easier.....
Old Jun 12, 2005
SODJAZERO's Avatar
were do i get check valves from?
Old Jun 12, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
Exclamation I got cel too
OK I been boosted for about 2-3 weeks now and my cel light finally came on. Car runs fine too. I know what you mean by car shutting off and on but its still fast. Is the missing link the reason my cel came on?
Old Jun 13, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Placea piece of sponge intead of the Filter, it works great...
Old Jun 13, 2005
andyman97's Avatar
Turbo Guru
Any auto parts store. It's just a standard GM 1 way check valve. All you do is run a hose into the spot where the map plugs in on the manifold and get 3 vacuum t's that you can run in paralell and run a check valve off of them and pull the o ring off of the map and connect it to the top with another piece of hose, its really easy.
Old Jun 13, 2005
SODJAZERO's Avatar
do you have a pic?
Old Jun 13, 2005
dezod's Avatar
7thgen Power Maker
We ran the ML for 8 months, no MAP sensor errors at all. Car never shut off or anything. ML worked fine. We even used the voltage clamp on the E-Manage and retuned, but the car reacted far worse for power and such with the E-Manage voltage clamp. We then went back to the ML.
The filter according to Synapse is necessary. It is important to keep it clean. I cleaned ours once a month good with soap and water to make sure it did not become too dirty. Maybe that is the key. We never threw any MAP errors related to the ML.
BTW what code are you pulling from the ECU?
Old Jun 13, 2005
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
hmmmmmm
Old Jun 13, 2005
SODJAZERO's Avatar
thats just the thing dezod, i wasnt getting an ECU error, dont know why not, but i wasnt
Old Jun 13, 2005
andyman97's Avatar
Turbo Guru
Here is a pic of the check valves.
Old Jun 13, 2005
so how many people are using the check valves? Do you need to use a V-afc? w/these?
Old Jun 13, 2005
andyman97's Avatar
Turbo Guru
Two completely different things. All the check valves do is bleed boost from the map so the ecu doesn't register boost. VAFC controls injectors. Check valves are a cheaper, easier alternative to a missing link.
Old Jun 13, 2005
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
That's what I have. Never had any problems in over 2.5 years, and a lot less expensive.
Old Jun 13, 2005
civicskater's Avatar
Chicks dig my scent
im gonna try the sponge idea...my filter is dirty as hell again, already cleaned it once back in december
Old Jun 13, 2005
in your setup are you using somthing like dsm450's? I was thinking that maybe you'd still need the v-afc or a afc to control your fuel. Sorry if this sounds stupid. I'm new!!!lol
Old Jun 13, 2005
andyman97's Avatar
Turbo Guru
I'm running precision 440cc injectors. They are for a d16 fuel rail because I'm running a d16 intake manifold on my setup. I'm controlling them with an emanage.
Old Jun 13, 2005
I see...you said you are running 10psi? on stock internals? Also did you dyno tune this setup? Thanks
Old Jun 13, 2005
why does the filter get so dirty?
Old Jun 13, 2005
SODJAZERO's Avatar
because its attached to the intake mani, and air is bleeded and vacumed through it
Old Jun 13, 2005
SODJAZERO's Avatar
thanks andyman97, im gonna see if i can get those check valves asap
Old Jun 14, 2005
andyman97's Avatar
Turbo Guru
I haven't completed it yet. Getting downpipe and intercooler pipes done this week. I plan to go to the dyno next weekend after I get my pipes powdercoated. I'll have numbers then.
Old Jun 14, 2005
andyman97's Avatar
Turbo Guru
No prob man. You can get them from napa or o'reilly.
Old Jun 14, 2005
Keep us informed on your setup!
Old Jun 14, 2005
SODJAZERO's Avatar
so i went to napa and o reilys, and they didnt have any check valves that looked like those, do you guys have a part number on those check valves?
Old Jun 15, 2005
andyman97's Avatar
Turbo Guru
Balkamp Check Valve - Universal One Way Vacuum -- Plastic
Item#: BK 7301347
Straight off of napa's website. Hit me up with some rep, man.
Old Jun 15, 2005
SODJAZERO's Avatar
+5 homey! ^
