Benifits of Porting and Polishing Head?
Old Jun 10, 2005
AlpineCivic's Avatar
What are the benefits of PNP? Will this be ideal for a FI setup?
Old Jun 10, 2005
sspem2's Avatar
em2
waht a port and polish does is you are makin the ports bigger so more air flow comes in and that equals more hp. yes its beneficial for FI. i got my head PnP, 4 angle vavle job, and manley vavle springs. good luck with it.
Old Jun 10, 2005
Michalo187's Avatar
Abortion Survivor
Do you guys have problems with over heating?? a Guy once told me his port and polished civic couldnt be driven very far because it started to overheat
Old Jun 10, 2005
So the new head and the crower internals offered by TrueHonda are a good idea for FI, Im assuming. How much PSI do you think I can push with all this done?
Old Jun 10, 2005
Michalo187's Avatar
Abortion Survivor
With all the crower products and some lower compression pistons probably about 15 psi i wanna buy all the crower products and low compression pistons and some other **** and run 15 psi but i got a D17A1 not an A2
Old Jun 10, 2005
djmota's Avatar
porting a head has nothing to do with an overheating problem.
Old Jun 10, 2005
Michalo187's Avatar
Abortion Survivor
Thats what i thought but thats what the guy told me i figure he just needed a better radiator
Old Jun 10, 2005
sspem2's Avatar
em2
yes if u wanna push 15psi u would need to build the bottom end completely IMO and mind as well when u got the motor apart build up ur head and cam. thats why i got my head done for insurance purposes u can say when i go turbo. i will build the bottom end and then boost cuz i wanna boost 15-20psi daily. make sure u get the stage 2 FI crower cam if u wanna do 15+ psi. i dunno if the stage 1 will work but if u wanna have lots of boost thats what the stage 2 is for.
Old Jun 10, 2005
I drive about 40miles a day so I was just planning to run about 10-15psi on a daily bases and be able to push a little more when needed. So I guess the stage 2 products it is!
Thanks for the help guys.
Old Jun 10, 2005
2K1Civic17"Gabe's Avatar
I bet if they fuc*ed up, and ported a spot too much where coolant flows through causing a leak, you could overheat. but, yeah, it shouldnt cause overheating.
Anybody know how much more boost you could run after a pnp? Dont they usually run a couple hundred? Plus a new HG.
Old Jun 10, 2005
Havok2k1's Avatar
Wicked Pissah Admin
Spend money on porting the exhaust port on an FI vehicle....
Old Jun 10, 2005
djmota's Avatar
porting a head will not let you push more psi. It will however produce more HP at a lower psi than before.
Old Jun 11, 2005
TheSmuggler's Avatar
We have a winner!
Old Jun 11, 2005
paradoxblue's Avatar
yeah wish i knew more about this kind of thing. i simply wanna drop a 75 shot of nitrouse in my car. but after hearing allt hese things im confused about blowing my **** up
i need to learn more about my engine but no matter how much i read itdoesnt click. i need to find someone who can talk with me about it. (only weay i can learn) sigh
Old Jun 11, 2005
right on, thanks a lot.
and the info on porting the exhaust.
Good info
Old Jun 11, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Bigger ports ≠ More flow.
hoofboy
Jul 17, 2015 04:27 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
General 7th Gen
Jul 9, 2015 10:17 PM
Ccoop87
Jul 9, 2015 03:26 PM
92hatchbackcx
Jul 7, 2015 08:23 AM
