im not going into boost, not spooling
Old Jun 6, 2005
shnivic's Avatar
shnivic is an unknown quantity at this point
why is this? this is a nightmare!!! my BOV is making a fluttering sound( well something is) and i am not going into boost, i dont get it, i got the max rev kit, vafc2my turbo is spinning but not spoolngi got a c2 autometer boost/vac guage and it idles at 20 but dont go to boost!!! help me please!!
boost pimp! please!!!
Old Jun 6, 2005
Michalo187's Avatar
Abortion Survivor
Have you check everything out? Do you have a missing link? How many pounds are you running? What boost controller?
Old Jun 6, 2005
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
yeh, first thing to check for is loose pipe connections
near couplers. if not there check vaccuum lines
Old Jun 6, 2005
civic01vtec's Avatar
werd
Old Jun 6, 2005
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
So the turbo is spooling but your not getting no boost right? If this is the case than you must have a loose pipe somewhere.
Old Jun 6, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
Max-Rev uses an external WG right? Which WG are you using? I'm guessing TiAl or Turbonetics.
Old Jun 6, 2005
diskreet's Avatar
if you arent too too knowledgeable take it to the garage who installed it.
if you installed it; good luck!
Old Jun 6, 2005
Michalo187's Avatar
Abortion Survivor
Yeah the first time i put the turbo on i stepped on it, the turbo spooled i felt boost. Then I floored it a second time and the pipe from the turbo blew off because i didnt have it tight enough. That could be it
Old Jun 6, 2005
2K1Civic17"Gabe's Avatar
I blew pipes off a few times at first. They are on pretty damn tight now. I hate boosting, than eharing a loud pop. It sounds so bad. hehe. It definately sounds like you blew a pipe off or have the vac line loose, pinched, im not sure. sounds like a boost leak though
good luck
Old Jun 6, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
something throwing off the harmonic waves.
Old Jun 6, 2005
good luck
I blew my charge pipe off of my TB the first time i took it for a run. Grabbed a can of hairspray and it has been tight ever since
Old Jun 6, 2005
I saw you typed that in another post. I still remember that, and will do it next time they give me probs. The last few months have been fine though.
Did you use extra hold, damaged hair, colored hair?? hehe j/p
Old Jun 8, 2005
HyaBoosta's Avatar
yeah it's def. the pipe that blew off. I suggest T bolt clamps for it if it keeps coming off. Git R done
Old Jun 8, 2005
MiamiUgen7's Avatar
what is your vacuum at idle? if it is around 5-10, you have a loose vacuum line. that happened to me once. but it is most likely the piping, check it all to make sure it is nice and tight
Old Jun 11, 2005
BudDyLeEBoOsteD's Avatar
BudDyLeEBoOsteD has a little shameless behaviour in the past
Yup.. Check all your clamps... make sure that all the pipes are together...
the ones i had problems with was the one with the blow of valve....and the other pipe was the one that came right after the turbo....
Old Jun 12, 2005
Michalo187's Avatar
Abortion Survivor
what should the vaccuum be normally??
Old Jun 13, 2005
20 idle
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
