135,000 points to you if.....
Old May 29, 2005
C2i0v0i1C's Avatar
SuperMODrizd
you can find me a fuel rail that needs no welding that will bolt up to my system and work flawlessly. im willing to replace with RSX size injectors, but have to be comparable to rc engineering 440s that i have now.
i cant find a damn fuel rail to meet my needs. so as the title says.
points will be awarded as soon as the solution is proven
Old May 29, 2005
i8dabomb's Avatar
I love to suck t3h c0ck & am supr ghey
i8dabomb is just really nicei8dabomb is just really nicei8dabomb is just really nicei8dabomb is just really nice
http://morepowerracing.com/prodtype....ageHistory=cat
Old May 29, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
they are for si, not em2
Old May 29, 2005
C2i0v0i1C's Avatar
SuperMODrizd
if it was that easy id have already had it
Old May 29, 2005
MiamiUgen7's Avatar
http://www.goldeneaglemfg.com/street.html
click on fuel rails
Old May 29, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
Originally Posted by MiamiUgen7
Points go to this guy
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
Im almost positive those are for 02+si civic and and NONE fit D17, unless its a recent release?
Old May 29, 2005
Blahman240's Avatar
k20's are SOHC? News to me.
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
IMO, the best solution is at http://www.rossmachineracing.com/customrail.html And then have some tabs tig welded to the rail where it would bolt down. They also sell bare fuel rails that you could buy and then have a local machine shop weld the tabs on and then mill out for the proper injector and spacing.
Old May 29, 2005
C2i0v0i1C's Avatar
SuperMODrizd
like i said once proven that it will work ill give them out
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
the SOHC rail they refer to is NOT for D17, its prior SOHC motors, and they are different.
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
My idea will work
Old May 29, 2005
C2i0v0i1C's Avatar
SuperMODrizd
My idea will work
ill look into that too
Old May 29, 2005
Blahman240's Avatar
ohhhh good point. Well... They could work... after all it is still a d-series.
Old May 29, 2005
tfnaaf's Avatar
BLDNPSI Mod
As i recall its been investigated before and was found that they are different enought to not work. But then again im sure it COULD be modified to make it work. But if your gunna do that you mind as well start with a blank fuel rail and make it right the first time.
Old May 29, 2005
civic01vtec's Avatar
yeah right, that **** doesn't fit our car.
I know a certain someone on this site is suppose to mass produce a rail for our car
Old May 29, 2005
MiamiUgen7's Avatar
isnt jwcardy doing that with ones that come prewelded for a return line?
Old May 30, 2005
andyman97's Avatar
Turbo Guru
PM jwcardy. He has at least one fuel rail that is a guarantee to fit. It is a stock rail with the fitting already on it. There it is, pm jwcardy and he'll respond. Good luck.
Old May 30, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I have a stainless steel one on my counter right now. It will fit d17 injectors and rsx injectors. It has 2 ports so you can plug one off or make it a return setup. This one has never been used. I made one for my old manifold and it worked great. I have a d16y8 now though. I was gunna sell them but nobody wants them. I got RCs to fit using the factory o-rings. The injector ports are cnc machined. I have made a jig for these and have parts to make 8 more.
Old May 30, 2005
02fpcivic's Avatar
These will support about 600hp and will never rust, corrode, leak, or explode. They have been pressure tested to hold over 150 psi. They will adapt to your factory fuel lines with a supplied list of parts( for about $15) or you can cut off the fitting and use a 1/4 inch hose barb with a 3/8 npt end. I have a lot of experience in making high end car parts. I will let these go for 125 plus shipping, which is pretty much a non profit sale, because I have been sitting on the parts for 6+ months and have not been able to get them out the door. Later guys
ID:	54779   Click image for larger version
Old May 30, 2005
02fpcivic's Avatar
If for some reason it doesnt fit for your setup ill split the shipping and modify it for no extra charge. I just need to get rid of the $750 in stock and machine work. I dont need to make money, just break even.
Old May 30, 2005
C2i0v0i1C's Avatar
SuperMODrizd
you want 750 for a rail
Old May 30, 2005
andyman97's Avatar
Turbo Guru
Originally Posted by 02fpcivic
... I will let these go for 125 plus shipping...
He only wants 125.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
sccarally
Texas
Jul 3, 2015 04:43 PM
juror
Jun 9, 2015 02:15 PM
sccarally
Texas
May 17, 2015 10:11 PM
CarbonFiberSi
Apr 21, 2005 07:50 AM
