AEM Wideband users READ
Old May 27, 2005
andyman97's Avatar
Turbo Guru
Ok, just a heads up for those of you using widebands.
A friend of mine is running an aem ems in his civic. He was using a uego wideband as well. Come to find out when he was on the dyno that he was over a half a point off! That's huge. Lean out by a half a point if you run a strong tune and you can do some damage.
Anyways, he started using the PLX after hearing some good things and has found on the dyno that it is much more accurate and within .2 point. Much less room for error. Just a heads up about info I had gotten and wanted to share.
Keep in mind a wideband is a good tuning tool but if you really want to run safe, get to a dyno and pay the 100-200 bucks it'll cost you. Much cheaper than the money and time of replacing the motor. Happy boosting.
Old May 28, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
i had aem wideband til they tried to charge me 250 for a sensor, f that!!
Supramk3
Jun 11, 2015 11:13 AM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
cukaracha
May 16, 2015 07:36 PM
vtechin
Dec 24, 2001 09:58 AM
Maximus
Nov 14, 2001 10:52 AM
