turbo installed help me
Old May 19, 2005
mxcivic's Avatar
mxcivic is an unknown quantity at this point
i just installed my custom turbo kit, and i run it, when i set de boost controller on low 4 psi it runs ok, but when i turn to hi 6 pi i can only see 3 - 3.5 can andybody now why is that?
Old May 19, 2005
2K1Civic17"Gabe's Avatar
What type boost controller do you have?
Old May 19, 2005
Make sure the settings are all set correctly to your wastegate. They have settings for external wastegate, internal wastegate, electronic pop off, there are a few settings. So just make sure its set correctly, and that the in and out are hooked up correctly. Are all the wires hooked up correctly, good ground??
Hope this helps, good luck
Old May 20, 2005
mxcivic's Avatar
i have the profec b spec 2 greddy
Old May 20, 2005
Do you have jumpers on the back of the control unit part. where you adjust it?? Make sure they are set correctly if so. Did you read my last post?? any answers?? those may help
Old May 21, 2005
mxcivic's Avatar
yes everything is correctly
Old May 22, 2005
dezod's Avatar
7thgen Power Maker
bump the gain up 1-2 points and try that
Old May 22, 2005
andyman97's Avatar
Turbo Guru
That profec b spec II is a pain. Make sure that every time you start the car, you cycle from hi to lo, then back to hi or vice versa. It was always inconsistent for me unless I did this.
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
