Question about Sf BOV
Old May 13, 2005
Michalo187's Avatar
Abortion Survivor
Ok for people who have the sf kit. With the bov does it need to be welded on? I was told that i have boost leak from the bov since its not welded on. I have never heard of anyone doing this. Also where can i hook up the vaccuum line to the bov to? thanks for the help.
Old May 13, 2005
civic01vtec's Avatar
There should be a flange welded on the charge pipe where the bov goes. There is a piece of rubber hose in that flange and you need to screw in a type of sheet metal screw to hold in the bov. Mine has been this way for over 1 yr with no problems.
You need to hook the vaccum hose into where your other vaccum hoses go. Behind the IM there is a vaccum hose that goes to your map sensor. You need to cut it and install a plastic tee fitting into it. From here u can hook up your bov, boost gauge and SF fuel system if that is what you are using.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
