about to install zex wet kit! Need pics
Old May 11, 2005
Tomola's Avatar
Tomola is an unknown quantity at this point
Heya Pplz,
I finally have my Zex Wet Kit in front of me!
I've been doing like 9 months research, have read the installation manual & everything! Feeling confident - wanna rip into the install!
I need some final pointers about where to mount the NMU (Nitrous Management Unit) and also where have u guys tapped(T'd) into your fuel line (pic of that would be sweet too).
Finally running the 55 Shot, is the No2 Jet #32, Fuel #17 going to put me in a good A/F ratio with my current setup?
Thanks
Old May 11, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
mnu?
Old May 11, 2005
djmota's Avatar
I made a bracket for the nmu and bolted it to the top of my intake manifold. I have seen other members do anything from zip tie to screw it into the rear center of the body where the vin number is stamped. [IMG][/IMG]
If those are the n2o/fuel sizes that the instructions say to use then they will be fine. for the fuel line buy 3 feet of fuel injection hose and some good hose clamps. ,remove your stock one and use the fuel injection hose for the splice. I double clamped my hoses just to be safe.
Old May 11, 2005
HeHateMe's Avatar
HeHateMe is an unknown quantity at this point
Here's where I installed my zex stuff.
Old May 11, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
I would mount your nozzles into that rubber piece that holds your intake to the throttle body. Seems to work the best and you dont' have to drill through your intake piping.
Old May 11, 2005
djmota's Avatar
thats a good spot for the non ABS people.
Old May 11, 2005
2K1Civic17"Gabe's Avatar
haha, I was wondering what that box thing was (ABS). I saw that on a few other civics, but mine was the only one w/o it. Thanks for clearing that up. I have a LX.
Old May 11, 2005
scatman's Avatar
Still in the game...
N2O = Sandblasting your pistons = No good.
edit: oops
Old May 11, 2005
djmota's Avatar
Originally Posted by scatman
NO2 = Sandblasting your pistons = No good.
N2O= more fun than NO2=
No sand in my engine how about yours.
Old May 11, 2005
scatman's Avatar
no **** theres no sand in ur engine, but in reality you might as well blast ur pistons cause thats whats happening every time you hit that button.....i would love to see what the inside of urs looks like....if you spray of course
Old May 12, 2005
Tomola's Avatar
I made a bracket for the nmu and bolted it to the top of my intake manifold. For the fuel line buy 3 feet of fuel injection hose and some good hose clamps, remove your stock one and use the fuel injection hose for the splice. I double clamped my hoses just to be safe.
That's what i'll most likely do. I'll tap into my metal intake, like most of you have done (and the instructions mention).
Only one last question is what about the hole? When I decide to pull out the kit at a later stage?
Old May 12, 2005
djmota's Avatar
you will have to use your imagination there. find a small rubber plug that will work or use a short bolt and plug the bulkhead fitting.
Old May 12, 2005
Tomola's Avatar
or should I just mount the nozzel in the rubber piece directly spraying into the intake manifold?
Old May 13, 2005
HeHateMe's Avatar
Zex says "Optimum Nozzle Placement Is 6" to 18" From The Throttle Body". That's where I put mine, works fine.
Old May 13, 2005
djmota's Avatar
that is the easy way. many members have sprayed from there with no bad experiences.
Old May 17, 2005
ImportRacer2123's Avatar
K20 Member
if anyone wants a push button for there nitrous setup I have the NOS remote button w/ cord. i will sell it for like $30 bucks. they go brand new in Jegs for $54.
Lopes101
Jun 7, 2015 08:04 PM
Youshoe
May 22, 2015 09:36 PM
toastyghosty
32
Dec 26, 2001 02:03 AM
Maximus
Bolt-on Engine Performance
Nov 14, 2001 10:52 AM
ImmortalEX
Nov 8, 2001 09:52 PM
