Problem....
Old Apr 15, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Problem....
Well last night after meeting with my buddies at my car club, and rracing around town, i started to have a few issues with the car...
As sson as i arrived at my Gilrfriends house, and stopped (not turned off), the car wanted to stall, and turned off even with the turbo timer being on, well i started it back again it kinda wanted to stall again...
I cheked the engine bay and saw nothing wrong, so i just let it cool for a while, i did the same thing when i started it back again and went home like that, when i steped a little on the gas the car just felt like it had nothing (no power, worse than stock), what could have cause the problem??
Blown HG?, Missing Link Filter Dirty?? Anything else??
Old Apr 15, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
sound to me like a vacumm hose or a charge pipe got disconeted
Old Apr 15, 2005
2K1Civic17"Gabe's Avatar
If its idleing low, almost about to stall, and sometimes stalls, it could be a MAP. When I had a crappy connection with the box that alters the MAP, it would cause that. It would also run very very very rich. I would try wiggling the wires you soldered (hopefully soldered) to the MAP, and see if its one of those connections.
Is it running rich as hell when that happens?
Old Apr 15, 2005
Thanks, i took a look at it, and the filter from the Missing link is gone, so thats it, cause i just turned the car on and when i placed my finger in the filter hole, i actually got better,
only problem is i dont have the filter any more, is there anything i can use instead?? (just for awhile)
Old Apr 15, 2005
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
Bump.. i wana know also
Old Apr 15, 2005
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
yeah, there is something that you can use...when my filter came out, i just pulled a piece off of my foam mop and used it...you can find foam anywhere..that is all that it is....just pull off a piece, and stuff it in the hole....trust me it will work...worked for me numerous about of times...i know that it sounds crazy, but just try it you will see...
Old Apr 16, 2005
Talking
Old Apr 16, 2005
jwcardy's Avatar
hahaha, let me know if it worked for you
Old Apr 16, 2005
Talking
Hurray i got my car back for the week end, i did have a foam mop but i used some from the scotch brite pad....
Old Apr 16, 2005
jwcardy's Avatar
glad it worked out for you man
Old Apr 18, 2005
When I need a filter, I use the laundry fabric fluffer thingys. The sheets you put in, in the dryer ya know. It works good, you only need one.
It just sounded like it had something to do with the MAP. my car would idle low, run rich as hell, and go nowhere. Those signs basically tell you to start with the MAP sensor, or missing link. at least in my case
Adam925
Nov 19, 2019 10:56 AM
woodsjd1
Apr 5, 2014 03:53 PM
SeanCZ06
Oct 18, 2012 05:45 PM
yamahamaxim700
Dec 29, 2011 09:35 PM
22Scout
Mar 29, 2011 02:02 PM
