did i get shafted?
Old Apr 5, 2005
dannn's Avatar
unique conformist
dannn will become famous soon enough
did i get shafted?
alright so i bought a t25 turbo off ebay
it was from a sr20det
the dude said it spools up fine and has no shaft play so i went for it since it was like only 100 bucks and there was like 30 mins left.
i just got it yesterday and i took a look at it
this is my first time ever handling a turbo so i dont know the condition of it
also i want to know what these are for
one of those for the wastgate? i think this one is supposed to be internally gated but it was taken off, if it is internal it is possible to use it with an external one?
also im guessing these would be where the oil lines go
which is in and return?
wat goes here?
one more thing
when i try spinning the turbine with my hand it moves but it seems a little stiff. is it supposed to spin freely?
please help out a noob with boosted dreams.
Old Apr 5, 2005
leonhsieh's Avatar
leonhsieh is an unknown quantity at this point
check if is there in and out shaft play. side to side is normal but excessive side to side is not normal. the turbo seems like is for external wastegate to me. the link below should help you a lot. http://www.beesandgoats.com/boostfaq...rbo.html#Turbo
Old Apr 5, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
This is the oil inlet fitting.
This is the oil drain.
Those are for the wastegate actuator vacuum lines.
wat goes here?
That is for the external wastegate flapper door. The wastegate bolts to the back of the housing.
That help?
Old Apr 5, 2005
C2i0v0i1C's Avatar
SuperMODrizd
the two eliptical places with the three holes, on with a square in the middle is for the oil feed and return. the little nipple things with the cube on them, are for the wastegate, well one is im not sure what the other ones purpose is, AND WHY DID U TAKE IT APART.
TO ME THE FINS LOOK BROKEN
Old Apr 5, 2005
dannn's Avatar
unique conformist
it came like that
i'll take a better pic of the fins
Old Apr 6, 2005
TheSmuggler's Avatar
t25's off the SR series are supposed to be internally gated...
Old Apr 6, 2005
dannn's Avatar
unique conformist
yes i know
but since the flapper is part of the exhaust flange im gonna convert it to external
Old Apr 6, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
..i dunon anything about turbos...but yes i think u got shafted sry dannn
Old Apr 6, 2005
dannn's Avatar
unique conformist
i think everything is fine cept the fact that the seller wasnt honest about the condition of the turbo
he said it was used so i dont expect it to be perfect
but he said it still spools up fine but i doubt it cuz its hard for me to spin it with my hands.
Old Apr 6, 2005
Boggie1688's Avatar
Diamond Member
How much do you think it will cost for you to overhaul the turbo? You should look into that...cuz for $100 bucks for a turbo...maybe an overhaul will do it good and would cost less than getting a new one. Good Luck dann
Old Apr 6, 2005
dannn's Avatar
unique conformist
a rebuild kit is around 90 bucks
i think i might get it since all the rings are worn out
Old Apr 6, 2005
Boggie1688's Avatar
Diamond Member
Yea thats not bad then. I retract my statement about you getting shafted, how about you got lied too kinda..sorta...
Old Apr 6, 2005
dannn's Avatar
unique conformist
yea i sent an email to the seller telling him that i think his auction was shady
i didnt leave feedback yet
i want to see what he has to say first
Old Apr 6, 2005
C2i0v0i1C's Avatar
SuperMODrizd
can we address this part
Old Apr 6, 2005
zachgeyer's Avatar
looks good now you just need hellea more stuff
Old Apr 6, 2005
Take a picture of the fins from the front.
Old Apr 6, 2005
dannn's Avatar
unique conformist
i'll take a few pics later today
Old Apr 6, 2005
It didn't look damaged from those pics, but they are blurry and its hard to tell.
speedlever
Sep 24, 2015 07:18 PM
pilebuck13
Sep 21, 2015 10:45 PM
Jrosa
Sep 14, 2015 08:24 PM
rainman15
Sep 6, 2015 11:10 AM
7thgensurvivor
Aug 26, 2015 06:17 PM
