K20a2 BIG problems
Old Mar 31, 2005
Dark2k1's Avatar
French ass K20a2 powered
Dark2k1 is an unknown quantity at this point
K20a2 BIG problems
I thought it was my TPS and I changed the Throtle body (will all the sensor on it)
But....
It still running slower than a pony...
I have this code...
AF ratio stuck lean
Cylinder 3 & 4 missfire
ELD high/low voltage
what the hell with this engine.. someone can help me??
Old Mar 31, 2005
Havok2k1's Avatar
Wicked Pissah Admin
compression test and leakdown 1st
Old Mar 31, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
bad ecu?
Old Mar 31, 2005
Dark2k1's Avatar
ECU is the one come with the engine.
I'll make a compression test tomorrow.
Also some people talk about the fuel pump. But I didn't see someone else did the swap and change the fuel pump
So... What I should do ?
Old Mar 31, 2005
Hawk's Avatar
You boost, I-VTEC
who did your wiring harness?
Old Apr 1, 2005
Em2Guy's Avatar
Em2Guy is an unknown quantity at this point
Heres My Input. Start By Changing 2&3 Plugs. Its Prolly Running Lean Because The Plugs Arent Firing. Youre Running On 2 Cylinders Mister!
Old Apr 1, 2005
Dark2k1's Avatar
I did the wiring.... but only 1 wire talk about the coils
Old Apr 1, 2005
HyaBoosta's Avatar
yeah check the plugs and do the compression and leak down test. You might want to test the resistance on the coil plugs too.
Old Apr 1, 2005
Dark2k1's Avatar
I try to switch coils to other place and the misfire stay on the 3 and 4 cylinder ... So I suspect I have a trouble with the fuel pump... I'll check the fuel pressure this afternoon
Old Apr 9, 2005
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
whats the update with this?
Old Apr 10, 2005
Dark2k1's Avatar
I change de fuel pump and check the entire wiring of the coils. But it seems I have a trouble with the spark plug, I'll have brand new one tuesday. I'll keep you inform.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
beveragemp
May 25, 2015 07:11 PM
bsmiley
Apr 27, 2015 01:27 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
