What would you get? A K20A2 or a K20A DC5?
Old Mar 21, 2005
KYjerry414's Avatar
KYjerry414 is an unknown quantity at this point
I have $7,000 saved up and i am debating on motor swap. Place is charging me 5,500 for a K20A2 motor swap and 7,500 for the K20A DC5 motor swap. I am eventually going to try and boost the engine in 2006. If you guys had $7,000 saved up which engine would you all rather get? I would invest in a new car but my civic is paid off and i want to keep my insurance cheap. If i get the K20A2 i will have some left over money to spend on the internals like cams or something. But the K20A DC5 would be sweeet just because its a Type R engine.
Old Mar 21, 2005
y.0. KiLLa's Avatar
Powered by Honda
hmm..i dunno..either way ur ride will be sick! but im a newb but doesnt the type r coem with like 20 more ponies? if i am correct just get the other one..i dunno..dunt listen to me...lol
Old Mar 21, 2005
hotrodcivic2004's Avatar
my civic has no boost
get the a2, and at least u have a great head start towards boosting.
Old Mar 21, 2005
KYjerry414's Avatar
I talked to the place that is doing the swap and they recommend me going for the K20A2 motor swap if i am going to boost it. But the Type R would be sweet just so people can drool when i hang out on the weekends. I mean both are high compression engines and i would have to lower the compression if i get either engines. the Type R does come with 20 more ponies. But the 20 more ponies really dont matter..its the LSD transmission.
Old Mar 21, 2005
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
k20a2 is fine save that 2000 to add mods. n/a dude...eff boosting
Old Mar 21, 2005
KYjerry414's Avatar
all motor?? Anybody know how much power the K20A2 produce for being N/A? I want to boost and get about 400 horsepower. I doubt i will get that much making an all motor A2.
Old Mar 21, 2005
lol u got that right. its ~200 horse. boost it to get another 200?....u gotta build up the internals after u get the motor. then get a big *** turbo and boost it to like.....20psi.
Old Mar 21, 2005
KYjerry414's Avatar
I plan on building the internals up before boosting. I'm guessing about 4,000 on the head job.
Old Mar 21, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
are more aggressive cams, better IM, lsd, shorter gearing and high stock rev limiter worth an extra $2000 to you? ... if so, then get the k20a
if you plan on changing it anyway, worried about smog or are going turbo, then get the k20a2.
do NOT turbo the k20a.
Old Mar 21, 2005
devilvtec's Avatar
devilvtec is an unknown quantity at this point
If youre gonna boost go with the A2, use the money you save to build it up.
Old Mar 21, 2005
KYjerry414's Avatar
We dont have smog test here where i live in Kentucky. I guess i will go for the A2..The shop here told me to go with the A2 if i plan on boosting. Why is the K20A bad to boost? Just because there is no difference when boosting either engine?
Old Mar 21, 2005
KYjerry414's Avatar
Does anybody know how much it cost to do a K series Hybrid? 24 block with 20 heads?
Old Mar 21, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
I the smog on the type r is the problem... but if you have a friend that works at a smog shop, or a guy that would take 40buckets to pass you, then you be fine...
boost the turbo, but I suggest getting the internals done before installation, it's save you time and money... DH Racing have a built K20, you should check it out... if you get the turbo added, it should get you to 400horses...
Old Mar 21, 2005
KYjerry414's Avatar
I guess everybody is in favor of the A2. I guess it would be hard just to find the LSD transmission off the K20A to go with the A2.
Old Mar 21, 2005
KYjerry414's Avatar
When i get my motor swap done i will have pics up with motor swap and pics of my car. I guess i will go with the A2 and build the internals up by end of this year. And boost it in 2006.
Old Mar 21, 2005
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
Don't waste your money on the K20A...get the K20A2. You are gonna end up upgradin ya cams, so the Type R cams are useless. Also, the LSD in the K20A isn't very strong, and you are gonna wanna upgrade to somethin like the Quaife LSD. If you like the look of the K20A valve cover, simply buy one for the K20A2.
Bottom line: get the K20A2, a Quaife LSD and K-Pro for starters.
Old Mar 21, 2005
KYjerry414's Avatar
good advice..I wil probably do that..Yah i was t hinking about getting the valve cover for the A2. Cant the transmission on the A2 be converted to Quaife LSD?
Old Mar 21, 2005
KYjerry414's Avatar
I'm assuming if i have 400 horses i will have to upgrade the transmission?? This could get really expensive.
Old Mar 21, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
Check out iceburgslim's ride, that convinced me where I want to go with mine.
http://www.7thgencivic.com/forums/sh...d.php?t=191934
Old Mar 21, 2005
It can, and will, get very expensive. Here is a list of items I have bought thus far for my swap:
K20A2 - $5200
Exedy Hyper Single - $894.70
Quaife LSD - $900
Koyo aluminum radiator - $322
Hasport mount kit - $540
Hasport wiring harness - $270
Driveshaft Stage II axles - $680
K-Pro - $909.18
Hondata IMG - $55.50
Mugen oil pan - $390
Mugen carbon fiber ignition coil cover - $350
Mugen fan switch - $49
Mugen thermostat - $90
Mugen oil filler cap - $80
Viscous Technologies short shift kit - $65
ClubRSX metal shift bushings - $20
Triple plated chrome valve cover - $250
Custom steel braided upper/lower radiator hoses - $250 approx
Labor - $750 approx
See how it can get pretty expensive? I haven't even done the swap yet!
Old Mar 21, 2005
diskreet's Avatar
i wouldnt bother with DC5 engine as you will spend just as much turbo-ing and building engine as with other K powerplant.
Old Mar 21, 2005
jttegx's Avatar
OMNES AD UNUM
k20a2, when all else fails, where would u find parts for cheap for the jdm k20?
Old Mar 22, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
um, do NOT go with a DH racing k20 block... you'll never get it.
C-Hamm
Sep 28, 2015 10:31 PM
Kyle Cargazm
Jul 16, 2015 02:06 PM
ClutchMasterOG
May 31, 2015 03:25 AM
NoBottleJustThrottle
North Cali
16
Mar 22, 2003 06:13 PM
trick000
Feb 10, 2003 08:56 PM
