Mex's trouble ticket: BOV problem.. stuck open?
Old Mar 12, 2005
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
hey guys, turbo's been running great now for almost 6 months, but i've now encountered a problem. just the other day, when i was driving each time i let off the gas and the BOV sounded, the sound would be all choppy, like the bov was opening and closing really fast. then, towards the end of the day, the BOV just started releasing air even when i was accelerating. after looking over all vacuum hoses and such, i realized the BOV is just stuck open :/ so my question is, what are my options? it's the BOV that came with the SF kit.. it sounded real nice too.
EDIT: ok i was able to take it apart and fix it.. i just used a very light coat of motor oil.
there's another problem that happened early on, and now it does it again:
after releasing the gas, sometimes the bov makes a high pitched buzzing sound. it only happens when the bov is opened completely to the top.. any ideas?
Old Mar 13, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Cleaning it out would probably be a good first step.
Old Mar 13, 2005
Jeff's Avatar
Jeff is an unknown quantity at this point
Clean it out really good. I just looked at mine (hasnt been installed yet) and it looks like it has oil to help it from getting stuck. Yours might be dry making it get stuck in the open or closed position.
Old Mar 13, 2005
Mex's Avatar
Mex
so it can just be removed and opened? i don't really understand how i can open it. haven't really tried to figure it out though, so if it's self explanitory maybe i'll try it
Old Mar 14, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Yeah thats the same thing happening to me , that BOV just sucks ballz
Old Mar 14, 2005
Oh, and the top Portion is just screwed to the lower part......
Old Mar 14, 2005
Brake cleaner and a little bit of light oil should do ya good.
Old Mar 14, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
just go buy a GReddy type s bov. not super expensive, dependable, and sounds really good. then you won't have to worry about it messing up again.
Old Mar 14, 2005
Titleist71's Avatar
wd-40....blow it out with airhose.....try it....they do get gummed up.
Old Mar 14, 2005
WD40 is not a lubricant.
Old Mar 14, 2005
bradmanuwf's Avatar
yes it is, just doesn't last as long as gear oil...haha
Old Mar 14, 2005
Mex's Avatar
Mex
would this be a direct replacement for the SF BOV? is it like a universal fit thing?
Old Mar 14, 2005
Mex's Avatar
Mex
ok i was able to take it apart.. i just used a very light coat of motor oil.
Old Mar 14, 2005
bradmanuwf's Avatar
no clue man....and I'm not sure about the fit of the greddy and sf bov. I know the max rev bov mounting flange works perfect. can't help you witht he sf bov though...sorry
Old Mar 15, 2005
to fi r a greddy bov you would have to buy the greddy flange and weld it into the pipe
Old Mar 15, 2005
Titleist71's Avatar
no crap, although you may think I'm not that stupid.....he needs to clean it. Depending on what the housing is made of (aluminum) I'm guessing, if the valve is brass as in the T-XS RFL when the two different metals rub they wear. You will see a black grime form on the brass/bronze plunger valve. CLEAN it with WD-40, not lubricate.....wow.....blow it out with pressurized air and re-assemble. I would keep the metal parts clean/dry and I would only recommend using lithium grease that comes in the spray can. Wipe off the excess. Use like a very light coat with your finger. Motor oil is too thick and heavy in my opinion. dirt and dust will cling to it...... But what do I know, this is just my advice......4drcivic2k1 seems to know it all.
Old Mar 16, 2005
Mex's Avatar
Mex
ttt, for the new issue
jessica19699
Jul 29, 2015 05:51 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
ballmich
Jul 9, 2015 11:59 AM
