Question about fuel system
Abortion Survivor
About how many pounds of boost could i run just by adding Rsx injectors and getting the Greddy E-manage? Its a cheap but easy system i guess and maybe a bigger fuel pump and thats it.
A.K.A BlackCar --- Not From Califorina!
if uve been reading.. a fuel pump wont work on our fuel systems, with the rsx injectors, im guessin u can run on no more then 12 pounds of boost? WILD GUESS though.. so dont listen to me, but with those injectors, people say when they get to about 220 whp they start running lean
a fuel pump will work on our cars... go to streetlevelperformance.com
i think you need the complete return line conversion though to make the fuel pump work..if you just have emanage and injectors, i'd prolly run 8 psi.. you can probably run 12 but your fuel pump will crap out really really fast...if you have the return line conversion then you can run as much as you want till your injectors max out and you start running lean.. when your tuner tunes it though, he'll be able to tell what you can run without leaning out
I'm going to covert to a return system using a y8 IM. you guys think can I run stock d16 injectors with a vortec FMU and be good to go? or have to upgrade the injectors to run like 6-7psi? and of course I'll get an emanage to retard the timing and make some adjustments.....
Originally Posted by bradmanuwf
Oh, I have some DC5 type R injectors that I'm not going to be using if anybody wants to buy them too.
What size are they? Are they bigger than type s injectors?
yeah but if you're boosting wouldnt you want some type of higher flow RC injectors?? I understand its a 6thgen rail but what kind of flow will you get out of a D16 injector? I see that you only wanna run 6-7 lbs but I've never met a person that turboed their car and 1 year later was running the same boost level they anticipated when they were originally designed the kit... I was mostly thinking about down the road ....
maybe down the road I'll upgrade and run higher boost, but for now i just want a little more go go and the pretty blow off sound...hehe. I'm going to get an evo in about 1.5 years anyway and that will be my daily driver and the civic will go into the garage for tinkering:P I'll be an officer in the navy in a year, so I'll be able to afford the fun stuff...lol I graduate in december and then go off to OCS and then after I grad. OCS, evo here I come
That's why I'm not too worried about going all out right now cause I won't be able to drive my car for 13 weeks starting in Jan. and then another 13 weeks after that when I go to D.C. for more training. Not taking my car up there to get stolen..bad, very bad.
That's why I'm not too worried about going all out right now cause I won't be able to drive my car for 13 weeks starting in Jan. and then another 13 weeks after that when I go to D.C. for more training. Not taking my car up there to get stolen..bad, very bad. 7thgen Power Maker
Originally Posted by HyaBoosta
I am running 8 psi with emenage and rsx injectors and there was still a good amount of room letf. so I say about 10psi max.
7thgen Power Maker
^word
If so, how did you ascertain more than 50% more fuel at WOT in the higher RPMS on the E-Manage, where she was just about running at about 12.0-12.5 A/F at 8 PSI on stock FP?
Our car was the exact same set-up and we were running out of fuel to add past 8-9 PSI because the E-Manage doesn not allow any more addition of fuel past 50% per individual cell and do you have a CEL of 1106 or 1107 because of the injector correction factor?
nope I never had a cel after the injector correction factor. I did tune using a wideband o2. SFP did my tunning for me and I wasn't in the car the whole time frank was tunning but we played it safe and had enough fuel to leave the ratio at 11:1 across @8psi. It was a good thing we left it rich too. I was running on the highway and was doing a 4th gear pull and threw a cell and when I checked it out it was because I ran too rich and primary o2 sensor voltage was too high. so I know we have some room to grow on those injectors. But I won't go any higher without the msd inline and the aquamist. next time I go by sfp I'll ask frank about how he did it.
oh when you tuned did you have the Missing link on with the emenage? Because that threw us all off for a while. We were leaning out and breaking up on partial throttle tunning but on WOT tunning it was fine. But after we removed the missing link we got the partial throttle smooth
7thgen Power Maker
CarStuff
Dec 6, 2020 12:52 PM
vtecbrah
May 31, 2015 01:24 PM
superstanko
Apr 28, 2015 04:38 AM
