RSX Type S Injectors
Old Feb 15, 2005
dchonda's Avatar
dchonda is an unknown quantity at this point
Can i save a few bucks short term and upgrade the fuel injectors to RSX Type S and upgrade the fuel pump/return system later?
Rather, is it absolutely necessory to upgrade the return system/pump?
Thanks
Old Feb 15, 2005
deciuss's Avatar
Boosted Auto
i belive if you uprade injectors if your running boost you dont need to do alcohal injection not sure no the fuel pump ect thow
Old Feb 15, 2005
Alex1's Avatar
im curious too, if u just upgrade injectors, will it support 7-8 lbs of boost?
Old Feb 15, 2005
Michalo187's Avatar
Abortion Survivor
yeah even stock would support that
Old Feb 16, 2005
TheSmuggler's Avatar
Yes, you can just use the rsx injectors (i hope you mean with emanage or some fuel correction) and no upgraded fuel lines.. but once you reach a high psi (usually past 8) your gonna wanna go return
Old Feb 16, 2005
2K1Civic17"Gabe's Avatar
what about running 12 psi, with a fuel system like TSIs, properly tuned? I believe 12 would be ok. I want to run 12 at the track and like 7 daily. for now that is, til I wanna step up some internals.
TSIs is like a carburater that spray extra fuel into the manifold. It is ok for around 8psi, but running 12 you are more likely to run into problems I believe. But for the track, Ill be fine. You dont need to do anything to the stock injectors other than get more fuel out of em, huh? maybe not even
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Luluharp
Sep 27, 2015 11:56 AM
anubis62
Sep 27, 2015 12:56 AM
speedlever
Sep 24, 2015 07:18 PM
