So close yet so Far!(Turbo Install) *Pics*
Old Feb 8, 2005
HyaBoosta's Avatar
Well I went after the turbo install this weekend but ran into a small problem. after removing and installing most of the parts I found that the IC pipe that goes to the compressor didn't fit and I have to shave my front buumper support a bit. so im back to stock and slow and going after it again this weekend. I think I wil try cutting a bit of the fan shroud to make some room for the pipe. what do you guys think?any ideas? don;t mind the dirty looking IC piping, I just have it like that till I get it running right then it gets powder coated
Old Feb 8, 2005
BIG's Avatar
BIG
so will you get to keep your A/C and your washer fluid resivoir?
what are the dimensions of your FMIC as well?
Old Feb 8, 2005
HyaBoosta's Avatar
yeah I get to keep everything. i'll measure the IC but it's 3"deep
Old Feb 8, 2005
BIG's Avatar
BIG
why can't you go around the other side instead of coming back across behind it? there isn't any room?
Old Feb 8, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
No, the AC compressor is in the way.
Old Feb 8, 2005
HyaBoosta's Avatar
AC and ABS is in the way
Old Feb 8, 2005
TheSmuggler's Avatar
Looks good.. I decided to rip my a/c anmd windshield washer res outta my EX to get my IC piping to run correctly LOL
Old Feb 8, 2005
2K1Civic17"Gabe's Avatar
Let us know how you end up doing it. I am ordering the same kit in a few days. Did you get it from needboost.com? If so, what type of fuel system did they ship you? Im curious since TSI has 2 options.
Old Feb 8, 2005
HyaBoosta's Avatar
nope it's not a kit. It;s custom made. The Ic piping and manifold were custom made by SFP
Old Feb 8, 2005
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Looking good man, you are almost there
Old Feb 8, 2005
HyaBoosta's Avatar
I know. I need my SLP stickers to put on when it's done
Old Feb 8, 2005
^^t3h w00t to sfp and slp =)
Old Feb 8, 2005
HyaBoosta's Avatar
^^ add a woot for AEM too. Lokk what I found in the new issue of turbo!
The answer we've been looking Fo!
Old Feb 8, 2005
I have no idea what that means for us but sweet! LOL.. you know they havea universal AEM EMS system.... so we can use it on the 7thgen,.... it just dosent come with maps lol
Old Feb 8, 2005
HyaBoosta's Avatar
that means that we have a way to tune our ignition for the first time and we can build our heads and rev higher up and use larger turbos and get more power.
Old Feb 8, 2005
I thought the emanage came with an ignition timing harness so we could tune
Old Feb 8, 2005
HyaBoosta's Avatar
yeah but this will let you not fry your coils when you get to a certain point
Old Feb 8, 2005
Hmmm... so we CAN do it, just not a crazy amount right now lol
Old Feb 8, 2005
BIG's Avatar
BIG
so there is NO WAY to run the IC piping the other way? damn, that sucks.....I was planning on running it through and keeping the AC and washer fluid
Old Feb 8, 2005
HyaBoosta's Avatar
you can but you would have to run the piping under the subframe and make sure you have some good suspension so you don;t bottom out on it. Thats what some mebers have done.
Old Feb 8, 2005
I'm afraid I'm gona yank my a/c and washer fluid bottle and STILL not have enough room. I gotta have my PS =)
Old Feb 8, 2005
tfnaaf's Avatar
BLDNPSI Mod
2 1/2" pipe ? GAWD im glad im going with 2" BTW interesting way of running the pipes, Thinking out of the box!!
Old Feb 8, 2005
tfnaaf's Avatar
BLDNPSI Mod
BTW what is keeping the charge pipe at the turbo from going lower?
Old Feb 8, 2005
BIG's Avatar
BIG
hmmm, I'm going to rip my bumper off and take a look....I really want to keep it on that side....I have Progress full coilovers but I've VERY low...
Old Feb 8, 2005
allmotor's Avatar
nor cal 7thgens
good luck on the rest of ur build up
Old Feb 8, 2005
HyaBoosta's Avatar
The front motor mount is in the way. but im cutting some of the fan shroud and pulling the radiator foward a bit to give some extra room for the pipe. This bigger turbo is getting to be a real tight fit. I have loosen the turbo to clock it back and forth just to put it in the bay.
Old Feb 8, 2005
tfnaaf's Avatar
BLDNPSI Mod
DAMN, what turbo are you running ?
Old Feb 8, 2005
HyaBoosta's Avatar
T3/t4 .48 Ar
Old Feb 9, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
just shave down the bumper support, many people do this anyways when they put a full front kit on their car...some people even remove it, although it is there for a reason
should have made arrangements for rides or have a beater so you didnt have to put the car back to stock and attack it the next weekend...
Old Feb 9, 2005
HyaBoosta's Avatar
yeah... but if it was that thought out and organized, then it would have worked right the first time. Now wheres the fun in that?
