Question About Buying Pistons!!!!!!!!!!!
Old Feb 8, 2005
BudDyLeEBoOsteD's Avatar
BudDyLeEBoOsteD has a little shameless behaviour in the past
I have the TSI kit,
I am thinkin about gettin a new set of Pistons,,
whats a good website that i could buy Piston for a pretty good price and those who knw for our cars.. Wich would be some awsome pistons to get when runnin TUrbo'd?
What do you recomend?
Old Feb 8, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Call Darius at CP.
949-567-9000
Old Feb 8, 2005
deciuss's Avatar
Boosted Auto
no one makes pistons or rods for us they have to be costome done most the major ones will make you a set if you send them your stock ones
Old Feb 8, 2005
Like I said, call CP. Their custom pistons are very reasonably priced.
Old Feb 8, 2005
Where is taht located?
Old Feb 8, 2005
and thank you by the way.>!
Old Feb 8, 2005
teampointless's Avatar
Ultimate Member
What a moron.
Old Feb 8, 2005
abmerop18's Avatar
Jam out with your clam out.
If you are going to get pistons, you might as well get rods and sleeves as well. Seem kinda pointless to pay a good amount of money to have the engine all taken apart and not do it all at once to save on additional costs later on.
Old Feb 8, 2005
True that!.
Old Feb 8, 2005
HyaBoosta's Avatar
crower already has a set of rods that can be purchased. this is what I heard back from race enginering.
The pistons are available in a 9:1 compression ratio. designed for high boost turbo applications. We have the rods in Crower billet. The kit with Pistons, pins, locks, rings and rods will run $1,168.00. The Compression height (wrist pin location) is different on the two pistons so it would not work.
Old Feb 8, 2005
What kind of pistons does that kit include?
Old Feb 8, 2005
HyaBoosta's Avatar
The pistons are our Xtreme Race brand, machined to our specification by Wiseco. The standard bore application shou fit ok providing there is not any wear in the cylinder bore. Sorry no springs or retainers.
Old Feb 8, 2005
HyaBoosta's Avatar
I was thinking about taking the pistons out of my spare block and sending them to cp though for a custom set. Ive heard they make the best LC pistons on the market now.
Old Feb 8, 2005
CP makes an excellent piston, but it is difficult to say "best" as there are so many good manufacturers. JE, Arias, CP, Wiseco, etc etc.
Old Feb 8, 2005
kezay's Avatar
kezay is an unknown quantity at this point
Crower has rods already for the D17.
Old Feb 8, 2005
tfnaaf's Avatar
BLDNPSI Mod
not following you. They make a kit but the two pistons so it would not work ???
Old Feb 8, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
i thinke he means you would have to buy the hole kit (Pistons, pins, locks, rings and rods), cuz they woulnt fit on stock rods...
Old Feb 8, 2005
streetglower's Avatar
on our car, do we need to remove the engine to remove the pistons, or can we do it by removing the head and oil pan and doing it that way?
Old Feb 8, 2005
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
no,just take off the head and oil pan.you cannot use the wiseco pistons on the stock rods so you'll need crower rods or other aftermarket rods..also with the crower rods you need to grind down some metal on the bottom of the cylinder wall.
and for the piston i think he was talking about the wrist pin location being offset compared to the stock ones.
vtecbrah
19
Jun 5, 2015 09:38 PM
zack22490
Apr 29, 2015 03:17 PM
bsmiley
Apr 27, 2015 01:27 PM
