new dyno results, but i also have questions
Old Feb 2, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Question new dyno results, but i also have questions
Today i took my car to a local shop and had my setup tuned on the dyno with safc and type s injectors. The result was 170lbs of whp and 162 lbs of torque at 6 psi. But the problem that i ran into was, i had the injectors turned all the way up and i could not get it to run any richer. So my air fuel is like in the 13s. Ide like to have it in the 12s and lower. My question to you guys is do you think i could run bigger injectors and run richer? Or do i need a bigger fuel pump on the type s injectors? Or do i need bigger injectors and a new fuel pump? This being with the use of my safc. Has anyone else on this bored ran the safc with type s injectors? I think someone else did but i dont know what the outcome was. Let me know what you guys think.
Old Feb 2, 2005
Wait isn't the ideal ratio 14.7:1? I'm not sure what you mean. Are you running lean or rich? Also, I think you should be using the e-manage with bigger injectors. The afc isn't that great with a turbo setup anyway.
Old Feb 2, 2005
SODJAZERO's Avatar
Ok well i was running like 13.0:1 on the air fuel ratio. Im using Type-S injectors. Are those too small for 6psi?
Old Feb 2, 2005
drjvic04's Avatar
drjvic04 is on a distinguished road
You might want to be careful man. I know you only had 6psi but the duty cycle of the injectors could be maxed out. I agree about the SAFC I have not really heard any good things about its tuning features. And E-manage would be better. Also get some RC injectors if your looking to turn up the boost a lot. But you should of been able to get more than 13.
To the other guy 14.7 is the ideal gas to air ratio. If he runs 13 its richer. Thats good because too much air will make the car over heat. When turbo'd you want it at about 12 at WOT. If he was closer to 14.7 the turbo would probably damage some engine parts. Due to heat build up.
Old Feb 2, 2005
turboengnr's Avatar
DONT PANIC
you need to be in the 11's to be safe. 12's will make more power, but if you get one bad tank of gas, it can kill the motor.
#1. Get some bigger injectors
#2. Return line conversion
#3. install fuel pump
Remember that 14.7:1 is the ideal air/fuel ratio for the cleanest burn. For a turbod street car, you want it in the mid-low 11's. For a race car, you want high 11's to mid 12's.
If you are leaner, it causes the EGT's to go up, and increases the chance of detonation. Detonation leads to blown head gaskets and broken ring lands. And that causes you to cry.
Old Feb 2, 2005
Listen to this guy
Old Feb 2, 2005
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
The in-tank FPR is killing that system. If it was external you could have just turned the dial
Old Feb 2, 2005
djmota's Avatar
just one thing I thought I should bring up. If you where using the dyno's tail pipe sniffer, then an exhaust leak will read lean. I had this happen on my last dyno and it freaked me out. Now that I have a wide band installed in line, and the leak is fixed, tuning my vafc2 is not a problem.
Old Feb 2, 2005
SODJAZERO's Avatar
what set up are you running?
Old Feb 2, 2005
djmota, is that why you were running so lean with the dh head?
Old Feb 2, 2005
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
I thought the Type S injectors were good for up to 10-11PSI. Isn't the E-manage more adjustable for fuel adjustments than the SAFC. Atleast thats what I thought. Thanks.
Old Feb 2, 2005
SODJAZERO's Avatar
I thought the type s were good for atleast 10 psi also.
Old Feb 2, 2005
I don't want to get different injectors, I just got my Type S ones on monday along with the emanage and harnesses
Old Feb 2, 2005
They are if you tune the injector duty cycle with the e-manage.
Old Feb 2, 2005
NashVegasEX's Avatar
NashVegasEX is an unknown quantity at this point
so what is the max amount of boost that can be achieved (safely) with type-s injectors and a return fuel setup, tuned with emanage?
Old Feb 2, 2005
Thats what I want to know
Old Feb 2, 2005
Thats what I want to know, don't tell I have to spend more more to go return line. God I love this car ****.
Old Feb 2, 2005
The best would be the return fuel conversion from streetlevelperformance.com then you can get an adjustable fuel pressure regulator and makes it a whole lot easier.
Old Feb 3, 2005
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
I ran 250whp on a dyno tuned with a VAFC2 on stock bottom and stock injectors. I would have ran aorund 270whp but the injectors were maxed out and it needed more fuel. I ran 12-14psi daily for almost a year with no problems. My A/F was around 13.. Once I stacked two headgaskets to lower compression I had no problems running 14psi. I even spiked to 15-16psi on the track.
I dont suggest trying this without the know how in tuning and a shop full of tools to fix whatever you break. BUt the mighty D17 can take a beating. Dont be afraid to turn the boost to 9psi for daily and 12psi on the weekends. Just make sure you run slightly rich.
Good luck to all. I just thought I would drop by and stir the pot.
BTW I am now using Emanage w/ profec EO1 on my Skyline. I will never use a SAFC and MBC(bleeder valve) again. The Greddy setup is very easy to use and tune once you get it setup. But if all you have is a FMU and vafc you can still make big numbers on stock setup.
Old Feb 3, 2005
Bastard you have a skyline, don't talk to me again lol. I'll be running the Emanage with the profec E01 along with the type S injectors. I think I should be fine. Besides I'm only looking to run 8psi. What skyline do you have an R32.
Old Feb 3, 2005
dezod's Avatar
7thgen Power Maker
On stock fuel pressure, with no return-line, I ran 8 PSI on the RSX injectors and maxed them out.
Old Feb 3, 2005
So what are you saying dezod I should go return line. Do you know if I would pass ispection with the return line with the stock cat.
Old Feb 3, 2005
deciuss's Avatar
Boosted Auto
dez did you have an inline pump when you maxed at 8 or just the stock pump and injectors
Old Feb 3, 2005
HyaBoosta's Avatar
I've heard of people running more boost on them (10psi) I think the problem with the afc is that it cannot rec. that the injectors are larger so it will only dump so much fuel. The emanage has the injector correction factor that works pretty nice. My RSX injectors are running smooth now.
Old Feb 3, 2005
How much boost are you running HyaBoosta and do you have a return fuel setup. Thanks for the info.
Old Feb 3, 2005
HyaBoosta's Avatar
im installing the rest of the turbo this weekend but I already have the emenage and rsx injectors in the car. I plan on running 8 this weekend
Old Feb 3, 2005
dezod's Avatar
7thgen Power Maker
I see your in LI......I am not sure if inspections are little more stringent down there, but here in WNY (Buffalo area), they really aren't. I'd say you could pass easily as long as you have no CEL's in the ECU
Old Feb 3, 2005
dezod's Avatar
7thgen Power Maker
No inline pump, stock fuel pump, stock FPR, RSX injectors & E-manage to facilitate fuel. 8 PSI on stock FP they max out. Trust me. The E-manage only allows you to add 50% more fuel than stock. we had 50% in a lot of the WOT spots on the table, and still were not running exactly where we had to be as far as A/F
Edit: I can't see raising FP with an inline pump for no reason. The return system is def the way to go. SF's fuel system is merely enrichment w/ lack of tunability. Just a quick fix to fuel IMO.
Old Feb 3, 2005
dezod's Avatar
7thgen Power Maker
Nice numbers....post the graph!
BTW, what size turbo are you running? T3/T04 B or E I presume judging by the power produced.
Old Feb 3, 2005
SODJAZERO's Avatar
ill see if i can get that up sometime soon
