New SF Fuel System ??? & Pics
Old Jan 24, 2005
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
I was just wondering if anyone can tell me what that smaller port on this fuel system is for? I thought it might be for a type of fuel pressure, but I am not sure. It it smaller that the 2 fuel lines? My instructions are not very clear.
Thanks
Name:	SF Fuel Pump 1.JPG
ID:	46065   Click image for larger version
Name:	SF Fuel Pump 2.JPG
ID:	46066   Click image for larger version
Name:	SF Fuel Pump 3.JPG
ID:	46067   Click image for larger version
Name:	SF Fuel Pump 4.JPG
Old Jan 24, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
That where you should place a boost signal.......
Old Jan 24, 2005
What sort of boost signal are you referring to?
Does that mean when it senses boost, it will up the fuel pressure?
Old Jan 24, 2005
civic01vtec's Avatar
hook into a vaccum line that connects to the stock vaccum line from your map sensor.
Your boost gauge, fmu and bov should be connected to this.
Old Jan 24, 2005
deciuss's Avatar
Boosted Auto
did you do the chex your fuel pressure before you took every thing off yet? you need to do that and then when its on the screw no the top alllows you to basicly tune the pump to your level of elivation i guess.
cutting the fuel line sucks blah lol
Old Jan 25, 2005
No, but I can do that in a few days perhaps...I can cut my fuel line & install a fuel pressure gauge to see what fuel pressure I am getting before installing this SF fuel system, then after installing it. With these two numbers, what should I be doing with it?
I assume that my fuel pressure gauge gets installed after the fuel pump, so it will be reading the higher pressure, so how do I go about tuning the pump for my elevation (and coldness of -20DegC)?
Another note is that I installed RSX injectors, should I put back in the stock ones before putting this turbo on? I asked Mike when he was making this fuel system to use a different compression ratio for these larger injectors, but I do not know if he did that or not? If not, there might be way too much fuel pressure for these larger injectore & spray too much fuel! But if he did & I put the stock ones back in, there might be too little fuel pressure! What fuel pressure should I expect?
Thanks for the help.
Old Jan 25, 2005
Am I on the right track here?
Please edit or modify if I am wrong anywhere.
Old Jan 25, 2005
^^^^^^^^^ yup, u got it
Old Jan 25, 2005
deciuss's Avatar
Boosted Auto
to be honest that drawing is really helpfull then a lot of instructions rofl.
you have to make sure when it idols the new fuel pump keeps the same presure as stock i guess.
CarStuff
Dec 6, 2020 12:52 PM
Wild Cranker
427
Jan 28, 2016 06:49 PM
vtecbrah
May 31, 2015 01:24 PM
TaiChi
Dec 17, 2001 09:09 PM
ImmortalEX
Nov 8, 2001 09:52 PM
