Questions about turbo?
Old Jan 17, 2005
Michalo187's Avatar
Abortion Survivor
First off i really wanna turbo my civic but i dont know to much about it. If ibought a complete kit would i need to modify my computer? What is alcohol injection?what else do i need to know i know the basics but not to much i need experienced people to help me
Old Jan 17, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
If you buy a "complete kit" then it should come with some type of "MAP" componet to trick the map sensor from throwing a code. (that should take care of the only computer thing you'd have to worry about other than running too lean or too rich outside of the ecu's fuel cut parameter and throwing a primary O2 high/low voltage code and then running in closed loop mode for a day or two.) Alcohol injection is an alternative to adding more injectors, piggybacks, or larger injectors. The alcohol compensates for the increased pressure and lack of fuel from stock injectors. I'd strongly suggest reading over the Turbo FAQ and coming back with more precise questions rather than n00b vaugories.
Old Jan 17, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
^^HaHa Serious.
-HondaFTW-
Aug 30, 2015 10:38 AM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
bhollie
Aug 12, 2015 09:58 PM
justcruzin125
Aug 11, 2015 09:09 PM
