Getting Closer to Turbo... :D
Old Jan 15, 2005
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
Talking Getting Closer to Turbo... :D
Hey guys, been visiting this site weekly for a while, but its soon getting to the point that i should be asking for some opinions. 2001 Ex 5spd, local shop in town said that i should get the t3/t4 turbo for the D16 because its selling for $950. http://www.ssautochrome.com/level.itml/icOid/1291 He said that i can either find a turbo manifold or he would modify the one that came with the kit.
The Questions i have are:
-Where would i find an decent aftermarket turbo manifold?
-What would i need for fuel system upgrades to run 5-10 psi? (rsx-s injectors?)
-What would be my best bet, between a VAFC vs an Emanage, and what brand and eaisest for tuning.
Thanks guys
Ryan
Old Jan 15, 2005
dragoon's Avatar
http://www.7thgencivic.com/forums/sh...d.php?t=174045
thanks.
Old Jan 15, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
it says d16, not d17, you may also wanna make sure the secs are rite
Old Jan 15, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Anything can fit for everything. Depends on $.
Do you have enough $ to make it fit?
Old Jan 15, 2005
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
Thanks guys
Ryan
actually you are not even close to getting turboed if you are asking us all these questions. Research thats what i did, and i can say i am close to a turbo, because i have everything in my garage, however we are expieriencing some cold *** weather now so i'm not even starting on it now. I already have some parts on now, but the 20 degrees fahrenheit weather is f'd up. the wrenches are so cold that you get a frostbite on your palms. Anyways reasearch, ALOT. And there's ALOT on this site that you can research.
Old Jan 15, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
I will nice to answer ur questions.
1. Manifold - Dezod, SFP, MaxRev, RevHard for T3's
2&3. Fuel System - RSX Injectors + E-Manage + Tunning or SLP return style, or SF Fuel System <----(good luke on that one).
Old Jan 15, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
oh btw they are right you are not even close to getting ur turboed. and do A LOT of reaches.
Old Jan 15, 2005
ShoelessEX's Avatar
The wheel is turning...but the hamster is dead
ShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to all
Id go w/a ball bearing turbo..but like they said...ur not even close to getting it yet! maybe the turbo itself...but you have to remember all the other $hit that goes along w/it...Id put aside at least $2000 for parts
Old Jan 16, 2005
Thanks for the help, i looked them over and i think that if i cant go with a custom manifold, i may give the maxrev a shot. I am hoping to get the kit in at low boost in the spring, until i work on my fuel system. My buddys uncle is a t&d maker, and he figures that the can hook me the downpiping, tap my oil pan and thinks he can modify the manifold for cheap $$$. (guy does some pretty nuts work with turbo sr-20's)
Anyway, will i need an exhaust right when the turbo is installed (low boost 3-5 lbs) I dont know if it would even flow enough air to make a difference?
Old Jan 16, 2005
Been researching for almost the past 8 months...just asking for opinions of the board as well as the local tuning shops.
Old Jan 16, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
don't even boost 1psi when u don't have a fuel system
Old Jan 17, 2005
QBoi's Avatar
Make sure to get it tuned...
Old Jan 17, 2005
tfnaaf's Avatar
BLDNPSI Mod
To build a turbo system properly with new parts you prolly looking at closer to $2500 UP . I can easily see myself spending close to $4000 or better by the time im done
Old Jan 17, 2005
C2i0v0i1C's Avatar
SuperMODrizd
i have the max rev personally, also the pict in the link is missing so much stuff, if u want good **** dont go with that, 950 wouldnt even cover my turbo and manifold let alone an intercooler and any thing else
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
solarpunk70
Apr 12, 2016 11:43 AM
tuvok
Aug 28, 2015 10:04 AM
adamdrives
15
Aug 8, 2015 08:53 PM
viperGTS
Jul 27, 2015 08:40 PM
