T25 WHP on 8 PSI?
Old Jan 4, 2005
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
T25 WHP on 8 PSI?
Ive searched and cant find anything, how much WHP are u looking to get with a T25 on 8 psi?
and is that enough for me to take an rsx-s?
Old Jan 4, 2005
abmerop18's Avatar
Jam out with your clam out.
this is a total guess, but probally around 160ish
Old Jan 4, 2005
TheSmuggler's Avatar
Type-s, no...
Old Jan 4, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
170ish tops. And yes, you can beat a type S out of the box with only 6psi. If you're racing one at 100mph+ you're def. gonna get owned though.
Type S: 170ish whp, 140ish wtq
boosted civ: 160ish whp, 150ish wtq (also the vic with an ex trans has the advantage with closer gear ratios.
but again, from a dig- drivers race. From a 30mph+ roll, vic. From a 100mph+ roll, Type S.
Old Jan 4, 2005
Boosting Daily
well, then again, they'd both be about even. At lower mph, the vic has the advantage with closer gears, but at higher mph the type s has the advantage with a higher top speed.
Old Jan 4, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Umm I'd have to say a type-s has a closer ratioed tranny than an ex....
Old Jan 4, 2005
Boosting Daily
Type S 2nd gear tachs out at 60, civic ex -50
Type S 3rd gear tachs out at hmmmm, like 85 i think, civic- 75
etc, etc
civic ex 5th gear (final gear)-130 tops maybe
Type S 6th gear tachs out about 140-150ish+
Old Jan 4, 2005
Boosting Daily
the civic has a smaller trans and the gears are shorter.
Old Jan 4, 2005
abmerop18's Avatar
civic lx 2nd gear goes to 62
once again. the civic lx pwns the ex
Old Jan 4, 2005
Boosting Daily
shorter gears puts max power down quicker than wider gears. Lx gets owned in the 1/4 (when considering a boosted lx and ex with the same set-up)
Old Jan 4, 2005
dezod's Avatar
7thgen Power Maker
T25 @ 8 PSI....................155-170 whp.
T3 @ 8 PSI......................175-190 whp
T3/T04 E @ 8 PSI..............200-215 whp
These seem to be the margins I have witnessed on the D17.
The predecessing D16 however..............
T25 @ 8 PSI....185 whp
John's Mitsu 14B @ 8 PSI
T3 @ 8 PSI......200 whp
T3/T04B @ 8 PSI...235 whp
These numbers have been witnessed first hand by myself. The previous D series motors were far more responsive to boost than ours.
Even all motor hatches reign hard.........Carrie's lil GSR swapped hatch:
^^Carrie's hatch is nice too..........nice TQ even in 3rd,4th and 5th........
Old Jan 5, 2005
allmotor's Avatar
nor cal 7thgens
nice dyno #'s. You should be able to take the rsx-s off the line.
Old Jan 5, 2005
Your in for a biiiiggggg suprise
Old Jan 5, 2005
Boosting Daily
Civic weighs less, and with 2nd gear taching at 50mph and more torque, vs heavier type S 2nd gear taching at 60+ with less torque.
you're right though, its still plenty close. I'll just have to try to take one, one day.
Old Jan 5, 2005
dezod's Avatar
7thgen Power Maker
Driver has a lot to do with it too.
I have seen SRT-4's run almost 15 seconds because of the driver.
Old Jan 5, 2005
Yeah, and Type-s's dont weigh THAT much more.. when you guys figure in weight vs power, then driver skill, weight has to be a pretty large differnece for it to take major effect.
Old Jan 5, 2005
Boosting Daily
/\/\ can't find it, grind it baby!
Old Jan 5, 2005
Boosting Daily
how much more does a type S weigh? I've heard it weighs more, but that's it, i don't know an exact number.
Old Jan 5, 2005
dezod's Avatar
7thgen Power Maker
RSX BASE
Manual: 2734 lbs (1240 kg)
Automatic: 2809 lbs (1274 kg)
TYPE S
Manual: 2840 lbs (1288 kg)
D17 MANUAL CPE EX
2598
D17 AUTO CPE EX
2657
Old Jan 5, 2005
300 really isnt that much when our talking about those hp differences and driver skill.. plus that unmoded horsepower, I dun know bout you but anyone who races their type-s by me isnt stock lol
Old Jan 5, 2005
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
do you guys really think that a t25 at 8 psi is only capable of 160-170whp? so if i boost on a t25 at 8 psi i will only see a gain of 35-45 hp over what i have right now?
Old Jan 5, 2005
well if you have an ex you have about 110 hp right now... so yeap rofl that would be between 50-60 ehp increase which is pretty damn good
Old Jan 5, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
t25 spools to fast and loses efficiency up there in higher rpms...go with soemthing bigger like a t3 super 60 or t3/t4 and u'll get more out of it...
Old Jan 5, 2005
T28!!! *runs away*
Old Jan 5, 2005
KalliGarri's Avatar
So what speed will i be going in the t25 by the time he passes me up?
Old Jan 5, 2005
The whole time.... lol
Old Jan 5, 2005
HyaBoosta's Avatar
Upgrade and get a T28 or T3 and stop being soft!
LOL j/k
Old Jan 5, 2005
KalliGarri's Avatar
i would get the t 28 but with that kit, it requires alot of modifications to make it fit in our car
Old Jan 5, 2005
Tis worth it, I'm telling you =)
Old Jan 5, 2005
Addicted To Boost
well actually i got 125whp, so what psi should i run to get 200whp and up to what psi can i boost on stock internals
