Water cooled turbo question
Old Jan 3, 2005
CRNewson's Avatar
CRNewson is an unknown quantity at this point
Looking to do a custom turbo install, but I had a couple questions...
Oil and water cooled turbo (advertised as oil *and* water cooled). With this setup, must I use the water cooling? Should I use the water cooling?
Next, does anyone have a drawing of the exhause manifold flange to the block, or know someone who sells just that flange?
Thanks for the input
CRN
Old Jan 3, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
Hack the radiator hose with two T fittings, 1 feed, 1 return.
Old Jan 3, 2005
Boosting Daily
Also you really don't need to hook up the water coolant lines. My turbo is oil and water cooled, but we only hooked up the oil coolant lines. Oil is sufficent. Oil and water is just to prolong the life of the turbo. Which turbos, already, last a pretty long time.
Old Jan 3, 2005
C2i0v0i1C's Avatar
SuperMODrizd
the word HACK and turbo should not be used in the same sentence, dont half *** anything
Old Jan 3, 2005
CRNewson's Avatar
I tend to agree with the above. There will be no "hacking" with this job. I do plan to use the turbo and wastegate out of an eclipse (so, if you know what the spring on the wastegate is set at stock, that might help) and an intercooler from something else (both used).
I'm still undecided on the intercooler plumbing. I don't know whether to go with welded aluminum, welded exhaust piping (that will be sent out for powder coating), or rubber. If you guys have any input on this, I'd love to hear it.
Also... Just thought of this... BOV, I would like to get something nice, but not spend too much money. Again, input here is good...
Thanks
CRN
Old Jan 3, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Tial for the blow off valve.
The water cooling is not required, but I would recommend it. The easiest way to plumb it is to run it off the throttle body heater, but there are better ways to do, which are slightly more complicated.
Old Jan 3, 2005
tfnaaf's Avatar
BLDNPSI Mod
Old Jan 3, 2005
Boosting Daily
Oops! Sorry guys! I agree, that was the wrong word for me to use.
Old Jan 3, 2005
Boosting Daily
.4 bar I'm pretty sure
Old Jan 4, 2005
.4 BAR sounds about right.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
Bruce.Ringler
Jun 18, 2015 08:12 AM
Supramk3
Jun 11, 2015 11:13 AM
Lopes101
Jun 7, 2015 08:04 PM
