t25 vs t3/t4 race
Old Dec 31, 2004
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
t25 vs t3/t4 race
a friend of mine has a t3/t4 garrett turbo in his 99 accord 4 cylinder. he runs at about 5 psi
when i get my turbo kit, im going to have a t25 turbo, itll spool ALOT faster then his, and im also going to be running at about 7 psi maybe 8
what do u think is going to happen?
Also when we do race, ill have a video to show yall if i got raped once again or if i win
Old Dec 31, 2004
jttegx's Avatar
OMNES AD UNUM
does the accord have internal work done or build-up? if so, i would bet on the accord.
if not, you would take him. make sure its from dead stop too cause you have advantage from that lol. remember: keep it safe on closed road or private road
Old Dec 31, 2004
sb143hd's Avatar
sb143hd is an unknown quantity at this point
I'm getting the SF kit, and my motor is at the machine shop being built as we speak, i'll be running 8 psi(alcohol injection too), and using a NX 35shot to spool the bigger turbo with a Pressure sensetive shut off switch! and judgeing by your name i take it you also from cali! hopefully so cal, if so I'll have to race you as soon as i get back from this **** hole called Iraq!
Old Dec 31, 2004
HyaBoosta's Avatar
the accord weighs more and is running less boost so if your running 8 then it's in the bag.
Old Dec 31, 2004
AceAltima's Avatar
AceAltima is an unknown quantity at this point
errr
somewhat true
the weight factor is going to be the deciding factor in most races, as a t25 at 8 psi will put out what a t3/t4 does at a lower psi...
BTW: I vote t25...quick spool+ light car is going to take the cake I think....
Old Dec 31, 2004
TheSmuggler's Avatar
That's what you think....
Old Dec 31, 2004
KalliGarri's Avatar
Not from Califorina! My user name means BlackCar in my language (Urdu) Pakistani Language!
Old Dec 31, 2004
OMG... Pakistani!
Old Dec 31, 2004
Oh and for my 2 cents, I vote t25 for the 1/4 mile since both of you wouldent max out, but an open highway hes going to stomp you, your gonna stop making power at about 6500 hes gonna keep making it lol.. just dont race to far and you can win all you want
Old Dec 31, 2004
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
T25 is very very small. It will fall off boost very fast. I guess its ok for daily driving.
Old Dec 31, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Originally Posted by AceAltima
errr
somewhat true
That is incorrect. At a certain pressure, the motor will only flow a certain amount of air. Does not depend on the turbo, however, the size will have an affect on horsepower due to the efficiency differences.
Old Dec 31, 2004
AceAltima's Avatar
/\ /\ Understood, I just worded it that way so they would understand the HP differences between the two....
You must read alot, I can see Corky Bell is your friend too ;]
Old Dec 31, 2004
allmotor's Avatar
nor cal 7thgens
i vote for the t25
Old Dec 31, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
T25!!! I walked on a cavalier with a T3/T4 and i'm pretty sure the cavi and accord have the same engine size and weight. My race was from 30-80mph w/ me a car ahead within seconds!
Old Dec 31, 2004
C2i0v0i1C's Avatar
SuperMODrizd
everything depends cant say for sure, are we talkin a f22 or what
Old Dec 31, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
All you have to to is brake boost, or use a 2 step rev limiter at the line, and you can spool the big turbo before the race even begins. Then Mr. "Turbo Smaller Than A Frog's Nut" won't have a chance.
Besides, the accord weighs more and you'll be pushing more PSI. You should get it easily.
Old Jan 1, 2005
AceAltima's Avatar
t25's are kinda cute tho aren't they ;]
Old Jan 1, 2005
*slap* lol
Old Jan 1, 2005
Boosting Daily
..................i at least enjoy mine.
Old Jan 1, 2005
AceAltima's Avatar
Hey cute girls are fun right?
so why wouldn't cute turbos be too?? lol
Old Jan 2, 2005
Wow soemones needs to get out lol
Old Jan 2, 2005
Boosting Daily
/\/\The man has a point! It's better to bring home a cute girl than no one at all!
Old Jan 2, 2005
civic01vtec's Avatar
Old Jan 2, 2005
LOL owned
Old Jan 2, 2005
allmotor's Avatar
nor cal 7thgens
they dont even sell kits off there site anymore
HondaGuy7
Feb 22, 2016 01:00 PM
krazykoncepts
Sep 8, 2015 09:02 PM
