Removing wastegate spring=No boost?
Old Dec 30, 2004
HyaBoosta's Avatar
Hey Im going to be starting the process of installing my turbo and I need to drive it to the shop after the install to have it tuned.If I was to remove the spring from the wastegate, that would leave the valve open and allow most of the exhaust to exit thru the dump tube and keep me out of boost more right?
Old Dec 30, 2004
C2i0v0i1C's Avatar
SuperMODrizd
i think removing that allows the turbo to spin as much as it wants, not a good thing
Old Dec 30, 2004
HyaBoosta's Avatar
^dam quick response and I never thought of that. good point.
So my best bet would be to leave the spring in and keep it under 3k huh
Old Dec 30, 2004
C2i0v0i1C's Avatar
SuperMODrizd
yea as long as ur not in boost i think it will be fine til it gets there, how far is it
Old Dec 30, 2004
dezod's Avatar
7thgen Power Maker
Not necessarily. It spins much more on a pressurized system (spring in WG)
The second that system builds any pressure the WG, having nothing to hold it in place closed, will fly open diverting all the pressure to the down pipe.
Old Dec 30, 2004
C2i0v0i1C's Avatar
SuperMODrizd
so which is the good thing
Old Dec 30, 2004
HyaBoosta's Avatar
well some pressure has to get thru. Im guessing it will cause it to spool later. theres no way that all that exhaust gas will exit that 1 3/4" dump tube
Old Dec 30, 2004
dezod's Avatar
7thgen Power Maker
Some will build, but next to nothing. Just keep the RPMS down and watch your boost gauge. No biggie.
Old Dec 30, 2004
dezod's Avatar
7thgen Power Maker
Actually I drove 40 mins away when I finished our first kit prior to tuning. So you can do it easy. Not to mention, I was even on the thruway some of it.
Old Dec 30, 2004
AceAltima's Avatar
AceAltima is an unknown quantity at this point
Removing the spring will allow more boost to run out the dump/exhaust pipe
Putting in to large of a spring will keep the WG from opening, causing it to boost to much
It's easy to stay outa boost...just drive like a grandpa in 5th gear lol Ive done it before
Old Dec 30, 2004
HyaBoosta's Avatar
so there shouldn't be any damage to it if I take out the spring right?(just to clear things up)
Old Dec 30, 2004
AceAltima's Avatar
No damage at all...
Old Dec 30, 2004
HyaBoosta's Avatar
thanks for the help guys I figured in theory it would be ok but since it's my first turbo can't be too safe.
Old Dec 30, 2004
Titleist71's Avatar
why take the spring out....just unhook the actuator arm if you have an internal WG. No messing with the spring.
Old Jan 1, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
I keep going back and forth about this same thing. The tuner I'm going to is 2 hours away from me and most of the drive is on the freeway.
Old Jan 2, 2005
HyaBoosta's Avatar
I have an external wastegate
Old Jan 2, 2005
Titleist71's Avatar
Hmm..yep it's different for me...Well f you can just take the spring out.
Old Jan 2, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Unless you have a really tiny turbo, you may be able to drive it without even removing the spring. Just keep the RPMs down and keep your foot out of it till you can tune it.
Sep 26, 2023 06:44 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
OptimisticWay
Jul 10, 2015 04:31 PM
Ccoop87
Jul 9, 2015 03:26 PM
ballmich
Jul 9, 2015 11:59 AM
