Turbo w/VTEC or Turbo w/o VTEC
Old Dec 28, 2004
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
Been reading all the information up and down and haven't found anything relavant to what I am about to ask.
I have a non vtec d17 motor and am possibly considering a turbo setup. Since reading an article on here comparing the D17A1, D17A2 EX Vtec and D17A2 HX Vtec, it seems to me there isn't much power difference other than 12 hp between the vtec and non-vtec motors (excluding the hx). How big of a difference will that make when you start turbo'ing the motors? Will having the vtec capability give you that much more of a hp gain over the non vtec motor when doing a turbo app?
thanks for any info
(ibsomeonesaysearch)
Old Dec 28, 2004
civic01vtec's Avatar
won't be much gain, but non-vtec motors have lower compression which is better for F/I.
Old Dec 28, 2004
C2i0v0i1C's Avatar
SuperMODrizd
in the end the vtec motor will produce more power, but even so, sleeve the lx non vtec and just swap in a head, should be cheaper than swapping the whole motor
Old Dec 28, 2004
opto_isolator's Avatar
OR - turbo the LX, swap the tranny with an EX tranny (better gearing), put a better cam in so it would essentially be like an EX - whalla, better setup!
Old Dec 29, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
Ditto on the EX trans/\/\/\/\ My ex tranny tachs out like a motha!!
Old Dec 29, 2004
Boosting Daily
I'm with C2i0v0i1C, sleeve the lx and get a Vtec head. The lower compression pistons in the lx and dx only really help when you're running alot of boost (9psi+)
Lx bottom end w/ Vtec head and ex trans........that'd be a nice setup
HondaGuy7
Feb 22, 2016 01:00 PM
Elciteeve
Sep 28, 2015 12:40 PM
Dave Brabant
Sep 27, 2015 09:43 PM
beanhead
Sep 24, 2015 12:04 PM
chiquita.banana
Sep 24, 2015 09:42 AM
