k20a3 worth it?
Old Dec 9, 2004
shibiku's Avatar
shibiku is an unknown quantity at this point
k20a3 worth it?
I was wondering, because i saw the thread on a k2oa3 for sale with everything for 1000+ship. Would it be worth it to put in my 04... just want a lil more power and was wondering if anyone new how much it costs to do the swap? thsnk
edited
Old Dec 9, 2004
allmotor's Avatar
nor cal 7thgens
a lil more power???? a k20a will give you great power and yes it will be worth it and k-series is only gettin better.... ask around or search because some people have done it and you should ask them. 1000 seems like a scam for a k20a mtr
Old Dec 9, 2004
dannn's Avatar
unique conformist
dannn will become famous soon enough
he said a K20a3 which is the base RSX/civic si motor.
i think as of now the K20a3 is a good option since it is a lot cheaper than the a and a2.
id rather turbo than get the K20a3. the a and a2 are different stories.
Old Dec 9, 2004
lucky13matt's Avatar
lucky13matt is an unknown quantity at this point
i just got done doing the k20a3 swap and i love it over the d17 motor.... im also planning on boosting it later.... buts that my opion
Old Dec 9, 2004
18inchpride's Avatar
18inchpride is an unknown quantity at this point
i would always rather have N/A powerband then a lagging turbo in my city, the weather is always changing in calgary, one day it sunny hot, and next its COOLLLLDDDDD and snowy, hehe, so K20A is a good option, but really its just too hard to save that kind of cash for the A2! so i would sayyyy f the K20A3 and just boost the B*TCH
Old Dec 9, 2004
TemjinX2's Avatar
the cost of swaping a k20a3 and a k20a2 is the same and costly. If your gonna spend that much money to swap then it'll be better to save for a k20a2. the 40hp is huge then again 127 to 160 is huge as well. i think u should ask yourself if you want it now or wait till you can afford a k20a2. I've seen k20a2's go as low as 3k, so its up to u
Old Dec 9, 2004
Alex1's Avatar
k20a3 is good if u plan on boosting it.
Old Dec 9, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
well.. take this into consideration and i already have parts coming in to do it..i am swapping in a k20a3..i also have a k20a2 head which is the type S coming in... basically the only differnece between the a3 and the a2 is the head.. the a3 has 2 intake lobes and 1 exhaust while the a2 head has 2 intake lobes and 2 exhaust lobes..so if you can find a cheap k20a3 then down the line swap out the head.. i have seen the a2 heads go for as cheap as 500.. but if u want to build your head find a k20a2 head without the internal parts which should be around 100-200 as i have found... then go buy some skunk2 cams and valves and springs and retainers and all that good stuff
Old Dec 9, 2004
allmotor's Avatar
nor cal 7thgens
i know he said k20a3 mtr u CAN make them quick
Old Dec 9, 2004
cordeez's Avatar
Member
cordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trusted
no i dont think so
Old Dec 9, 2004
the last 2 posts of you guys up there didnt make any sense
Old Jul 12, 2005
Sup3rMariO's Avatar
Sup3rMariO is an unknown quantity at this point
so the only difference is that one exaust lobe? how does that make such a difference in the a3 and a2?
Old Jul 12, 2005
EM2typeflex's Avatar
EM2typeflex is an unknown quantity at this point
Personally I think it is definately worth it. And anyone intersted in doing a K20A3 swap, can buy mine for cheap with an itr six speed transmission.
Old Jul 13, 2005
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
Hey i have a A3 out of a base RSX and i love it, I just made up for not buying the type S by turboing the A3. Its a very good motor and has lots of potitential.
Old Jul 13, 2005
atl01's Avatar
Hey lucky13matt you should drive up to the Ga line and ill drive down and meet up with you one time. I would really like to see another A3 swaped vic.
Old Jul 13, 2005
exturbo6's Avatar
for a G id get the swap. its alot better the the d-block and responsed to mods very good. i need to find a deal like that.
Old Jul 13, 2005
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
Like everyone else, I would say that it depends on what your performance goals are. As everyone else says, A3 would be better if you are going to boost and the A or A2 would be good if you are going N/A. You can boost the A or A2 but they already have high compression. Also, you can always swap the A3 head for the A/A2 head later down the line and upgrade the ECU.
Old Jul 13, 2005
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
Get the A3! why... swap an a2 head on there, K Pro = 240whp!!!
Eddie
Old Jul 14, 2005
acjones21's Avatar
4 cyclinders down, 4 to go.....
acjones21 is an unknown quantity at this point
Eddie
if you try and rev the a3 block w/ a swapped a2 head to the 8600 rpm limit that is imposed with hondata #4 (i think) you'll have rods everywhere at 8000. There is a BIG difference in the bottom ends in those engines. Just get Hondata for the a3 and you'll still get 170whp with boltons, in a vic that'll whoop a stock type S b/c of weight differences.
Old Jul 14, 2005
Anyone who knows anything about boost knows lower compression engines respond better to high boost levels. Like xproductionz said the motors of a k20a3 versus the k20a2 or k20a basically come down to a difference in cylinder heads. So considering the price of a k20a2 somewhere around 4000 compared to a k20a3 1500, it would be a good start. Do the k20a3 swap, then boost and head swap later. Yeah the guy above is right about the revving potential of a k20a3, but revving is for high compression engines as boost is to low compression engines. What's a little sacrifice of revving for a high horsepower boosted enigne. Forgot to mention you probably can't boost too much, due to the k20a3's shitty crank and rods.
Old Jul 14, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
GREDDY t-kit for K20a3 w/o FMIC advertised for 240 whp without any internal mods. longer gears in a3 are better for acceleration w/turbo.
I think for 1G + Homemade t-kit = 220 whp with no sweat.
Good daly ride at the end.
Old Jul 15, 2005
kileryoyo's Avatar
kileryoyo is an unknown quantity at this point
I have been running the options through my head and I think for my own project the a3 is right up my alley. I dont too much power just more and for my budget the a3 makes more sense. I thought about building my d17 for higher boost but saw that would be about 3k without adding the turbo to it. Then I would still have an automatic tranny to swap about another 1800. So I would love to get a complete a3 and do the whole thing for less than the 4800 it would cost to bring my d17 up to par.
Old Aug 31, 2009
silvercivic203's Avatar
New Member
silvercivic203 is an unknown quantity at this point
Re: k20a3 worth it?
hey i got a k20a3 motor i will be disecting thru the winter an hoefuly putting it in in spring how much b.s. do i need to worry about when putting it in? like cutting grinding that type ****.thanks
Old Apr 1, 2010
WestKendall's Avatar
WestKendall is an unknown quantity at this point
Re: k20a3 worth it?
i got a k20a3 for my 91 civic ef .. wat do i need to do the swap??
Old Apr 5, 2010
D rocks's Avatar
D rocks is an unknown quantity at this point
Re: k20a3 worth it?
how much?
Old Apr 5, 2010
02civicsi02's Avatar
Low and slow!
Re: k20a3 worth it?
Originally Posted by D rocks
how much?
He posted that 5 years ago.
Old Dec 29, 2016
TheHondaNewb's Avatar
TheHondaNewb is an unknown quantity at this point
Re: k20a3 worth it?
I have a d17a2 in my 03 ex, what all did it take to do the swap? Wondering because my engine is about done with its life.
Old Dec 31, 2016
qnzboiboi's Avatar
qnzboiboi is an unknown quantity at this point
Re: k20a3 worth it?
let me know if you find out the cost.. I just blew my d17a2 I was thinkgin about buying a K20A3, But I havent had any luck finding the cost of the build
Old Jan 4, 2017
brotatochip1000's Avatar
brotatochip1000 is an unknown quantity at this point
Re: k20a3 worth it?
You can find used k20a3's for like $1,000 shipped off ebay and other sites. I am currently in the process of swapping a k20a2 into my '02. I have found it is much easier to just buy a donor car
Dawit Melese
Oct 4, 2015 08:02 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
Jrosa
Sep 14, 2015 08:24 PM
Bikergofast
Sep 12, 2015 01:36 PM
