Return Fuel System Question
Old Dec 8, 2004
ShadowCivic's Avatar
ShadowCivic is an unknown quantity at this point
Hey everyone i've been looking at buying SLP's return fuel system and I was wondering if I would need anything else besides this kit to control the fuel for my custom turbo kit. Would the E-manage still be needed or is a FPR good enough? also has anyone installed one yet? Thanks
Old Dec 8, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
hey man, i have the SLP return fuel kit on my car...i have been running the kit on my car for several months now...jeff and i built it and installed it together on my car...my car was the test car for the kit.....we tested it for several weeks before SLP actually released the kit to you guys...but as far as you custom turbo kit goes, i would suggest that you always get some type of fuel management not matter what...the emanage is an excellent idea along with some type s injectors...with that combo you will be able to provide the fuel that you need for you kit...let me know if you have anymore ?'s
Old Dec 8, 2004
civic01vtec's Avatar
yes, you will need to use a some type of piggy back........e-manage being the best route.
Old Dec 8, 2004
allmotor's Avatar
nor cal 7thgens
how much did u get the kit for?
Old Dec 8, 2004
civicskater's Avatar
Chicks dig my scent
i say go with emanage...after you understand it (which is difficult at first) things go extremely smoothly...what doesnt kill you makes u stronger, plus i liked the learning experience
Old Dec 9, 2004
So what is the advantage of the return system as compaired to the returnless? If I can use RSX injectors and the Emanage with a stock fuel rail, why convert it over to the return system?
Old Dec 9, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Modifying fuel pressure up to 70 psi plus having a pump that can handle it. The ideal setup would be RSX Injectors, Emanage, Return Conversion Kit.
Old Dec 9, 2004
Thanks for the good answers guys but one last question. How much fuel pressure can the stock fuel system handle?
Old Dec 9, 2004
Your Parts Guy
The stock system has an in-tank FPR so it isnt adjustable.
Old Dec 10, 2004
But with the E-manage the stock system (w/ RSX injectors) is adjustable right? If I want to run 8psi daily and 10psi for the track is the return line needed? When does the return line become a must?
Old Dec 10, 2004
Your Parts Guy
I'd rather turn the adjustment **** with a hex key on the FPR than play with the injectors. A return style fuel system with an adjustable FPR is the best way to control fuel pressure.
Old Dec 10, 2004
AceAltima's Avatar
AceAltima is an unknown quantity at this point
Exactly /\/\ Maxing out injectors to throw more fuel to the motor will cause premature failure of the injectors and the pump itself (as will happen to most parts that you push beyond optimal efficiency range)
The return system will save you tons of headaches, and enable you to run a larger rail with a larger fuel pump more easily and with less headaches...
CarStuff
Dec 6, 2020 12:52 PM
vtecbrah
May 31, 2015 01:24 PM
viper775
Dec 9, 2001 10:52 PM
