.80 A/R T3/04 w/ Nitrous
Old Dec 3, 2004
flowerpowerlove's Avatar
just breathe...
flowerpowerlove is an unknown quantity at this point
hmm, just thinkin but, what if some one threw on a larger than normal t3 turbo and ran spray to assist spool. given a totally built engine...seems like most of the t3 in kits are .48 or .60. obviously for street smaller (to a point) is beneficial due to faster spool times, but run the spray till 3800-4000 then BIG flow from BIG turbo all the way to red...any thoughts?
too much for the ol D17?
Old Dec 3, 2004
allmotor's Avatar
nor cal 7thgens
unless u get a good fuel system/fully built motor its possible, but using nitrous and turbo on the street alot will cause something to break.
Old Dec 3, 2004
abmerop18's Avatar
Jam out with your clam out.
sounds like a good plan for explosions. i cant see that happening. .80 a/r is huge. thats bigger than the turbos some supra use.
Old Dec 3, 2004
C2i0v0i1C's Avatar
SuperMODrizd
to big period, ull never get the turbo to its optimal performance position. might as well stick with the nitrous. turbo is just to big way to big for this cars engine
Old Dec 3, 2004
drjvic04's Avatar
drjvic04 is on a distinguished road
It may be big. But there are always the around stuff like this. How about using the vane design on garrett turbos. It allows for the turbo to be effective even under lower RPM's. So by the time you get to WOT and able to get the turbo to its maximum effciency you have more turbo where you need it. Goto the garrett site and look around.
Old Dec 4, 2004
just breathe...
what about .60?
Old Dec 4, 2004
abmerop18's Avatar
60 would be much better
Old Dec 4, 2004
Jrfish007's Avatar
Then you would have a drag car... Not a street car. The car woudl probably stall out if you tried to take off at anything less than ful throtle. Can it be done, yes, would it be use full anywhere other than the strip, no. That is the way moat drag cars are set up, when I was talking to Don Garlets he built a Camero that ran twin turbos and used nitrous to spool them up. His nitrous system then was hooked into the pressure gagues for the intake manifold and as pressure built it slowly cut the nitrous off. He also siad he paid over 5G's just for N2O system though. Not to mention he rebuilt the frame too to handle that kind of power.
Old Dec 4, 2004
Got Boost???'s Avatar
HKS T51R SPL
with an A/R of 1.00 you should have no problem spinning this
Old Dec 4, 2004
civicskater's Avatar
Chicks dig my scent
LoL...redlining and still going no where...what a good way to spend your money
Old Dec 4, 2004
johnnyslil01ex's Avatar
Soon to be Mr. GST
johnnyslil01ex should not be trustedjohnnyslil01ex should not be trustedjohnnyslil01ex should not be trusted
a 60 trim is still too big for the little fart canon 1.7....its a piece you'll be in boost @ what 4500 rpm, jesus h christ that suck donkey *****
Old Dec 4, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Trim and A/R are two completely different things. A/R details the housing dimensions, while trim shows wheel design. Saying a turbo is an .80 A/R is to big without knowing turbine wheel specs is completly uninformed.
Old Dec 4, 2004
just breathe...
not all of us have the knowlegde you do, please dont take it out on us...
Old Dec 4, 2004
I'm not taking anything out on anyone, just stating the fact before people spew incorrect information.
Old Dec 5, 2004
just breathe...
okay cool
Old Dec 6, 2004
AceAltima's Avatar
AceAltima is an unknown quantity at this point
Understood, and you make a vaild point, but I can't think of any wheel +.80 housing combo that would flow well with a lil 1.7....there just isn't enough exhaust to spool it...
Personally, for a 1.7, I'd suggest a t28 with .80+ a/r...you'll gain great spool time and MUCH more midrange power
Trust me, a big a/r t28 will put a huge goofy grin on your face when you have it at spool around 2400 rpm :]
Old Dec 6, 2004
That makes no sense. You say that you can't think of any .80 A/R that would work with the D17, then go on to say a T28 with an .80 A/R would be good?
Old Dec 6, 2004
AceAltima's Avatar
werd....i know they are about the same, but the difference is in the pudding my friend
check out the sentra forums for further discussion into that...
a .80 in the t28 spools MUCH faster than it's counterpart of hybrid nature on the sr20
Old Dec 7, 2004
I'm not talking about the turbos. I'm talking about you completely contradicting yourself.
Old Dec 7, 2004
AceAltima's Avatar
No no no my friend, lol I see where your confusion starts...
When I talkeda bout a not finding a .80 a/r and wheel combo that wouild work on the 1.7 I was referencing that to the t3/t04b combination
sorry about my poor typing, i'm doing this on army time ;]
Basically I said
.80 a/r on a t3/t4 isn't going to be good
.80 a/r on a t28 will be happy
again, trying to do this as quick as possible so i don't get caught lol
Old Dec 8, 2004
MadWheel's Avatar
Premium Boosted Member
You can have soo many setups out there for custom housing and wheels. Using a large wheel is for more top end with more lag. Smaller is of course the opposite. AR stands for aspect ratio. If you have an 80AR (intake side I presume), then you could possibly run a .48 exhaust side. Keep in mind, the intake side is affected by the weight. If you have a big-*** wheel then there is naturally more mass involved. Your engine is powering the turbo with air, so more mass can atually have a great effect.
Ideally, a .60AR intake, with a .48AR exhaust is perfect for out car. Preferrably a Super trim. A ball bearing upgrade will help as wheel, and have at least a 2.5" intake pipe.
What would be sick, now that I think about it... (I'll be emailing some companies now...) what about a titanium compressor wheel? Something replacing the heavier wheels. You could run more aggressive A/Rs with less lag and still run cooler than normal turbos. Do you think titanium can withstand speeds up to 60,000rpms? I'll find more out on this and post up what I know.
Old Dec 8, 2004
MadWheel's Avatar
Found a starting bit of info...
Anyone actually considering trying this now? I wonder how much it would cost.
CLICK ME
Forcedperformance.com makes custom turbo applications. If you get a custom turbine made from Borg Warner, then send it to FP, you might have a possible killer setup. Wonder how much it'd all cost?
Old Dec 8, 2004
Jrfish007's Avatar
titanium could probably spin as fast as you want with out any problem, presuming it is machined correctly. The cost for titanium piece like that... I could image about 2-3G for that much titanium plus machining which will probably cost another grand or so (high precision with super hard metal is not an easy task). If done it would be nice...
Old Dec 8, 2004
MadWheel's Avatar
yeah haha i was figuring that...
imagine that though huh? untouchable lol
Old Dec 8, 2004
drjvic04's Avatar
Okay try this http://www.honeywell.com/sites/ts/tt/
Old Dec 8, 2004
Titanium is heavier than aluminum.
Old Dec 8, 2004
Jrfish007's Avatar
Aluminum turbo = BAD
Aluminum is way to soft, maybe alloyed with steel or something, but then you're heavier than titanium agian.
Old Dec 8, 2004
Jrfish007's Avatar
Yeah... that would be pretty bad azz
Old Dec 8, 2004
allmotor's Avatar
nor cal 7thgens
dam .60 is enough for me
Old Dec 8, 2004
We're talking compressor wheels. Most turbos currently produced have aluminum compressor wheels.
xproductionz
Jun 30, 2007 02:33 PM
Dmowerz34
Oct 20, 2006 01:14 AM
Boosted2k2
Engine Swaps
20
Jun 16, 2003 01:05 PM
