Fuel Injectors
Old Nov 30, 2004
Michalo187's Avatar
Abortion Survivor
Fuel Injectors
Where can i find some bigger fuel injectors for a 2001 honda civic lx? If i got fuel injectors would i need to upgrade anything else?
Old Nov 30, 2004
HyaBoosta's Avatar
you can use rsx-s injectors and all you need is a longer bolts and spacers. and a way to control them. SAFC VAFCII EMANAGE Ect...
Old Nov 30, 2004
civic01vtec's Avatar
2 threads
Old Nov 30, 2004
bigger injectors are worthless unless u are boosted
Old Nov 30, 2004
Michalo187's Avatar
Abortion Survivor
not really because no matter what more fuel is more power
Old Nov 30, 2004
Michalo187's Avatar
Abortion Survivor
can you control them with the venom control module?
Old Nov 30, 2004
ummmm..............maybe you need to reasearch some more
Old Nov 30, 2004
fuel w/o additional air =
Old Nov 30, 2004
jturbolx's Avatar
jturbolx is a jewel in the roughjturbolx is a jewel in the roughjturbolx is a jewel in the rough
well maybe a little more power if it is tuned and if it isn't you going to loose a lot more when you burn you cat up and clog it!! =)
Old Nov 30, 2004
if you give yourself more fuel.........then you will run rich. You will then lose power. You will have more power when you run in a lean condition.
BTW...........stock injectors are more than enough to supply sufficient amount of fuel compared to your mods.
OBD II's are a wonderful thing
Old Nov 30, 2004
gotti's Avatar
yeah, you are so totally right. If more fuel is better, why don't you just contact RC injectors and tell them to make you some 1600cc injectors for your stock civic. Better yet, go order 2 more fuel cells and 2 Inline pumps to pump all that fuel into your engine....because like you said, more fuel is more power.
If you come on here looking for help, don't argue with the people who no more than you do. Your stock injectors are not even maxed out on the duty cycle, so why the hell would you want bigger ones for a stock civic engine. You act like we have 8 liters of displacement. Yo douchebag, we drive a 1.7 L SINGLE overhead Cam engine...designed to be an economy car.
So go ahead, get some bigger injectors. I'm sure somebody will put to good use your wasted money.
Old Nov 30, 2004
cdmx's Avatar
Whats this doing in members rides???
Old Nov 30, 2004
cdmx's Avatar
Does a VAFC not add more fuel if you want to adjust it that way?
know what im talkin about
Old Nov 30, 2004
yeah, you can adjust the fuel curve with the vafc.......but depending on mods, not really worth it IMO.
Old Nov 30, 2004
cdmx's Avatar
yes yes
so i was just gettin at that your statement wasn't 100%
Old Nov 30, 2004
C2i0v0i1C's Avatar
SuperMODrizd
that is such a general statement. its relative to the ratio. u can add all the damn fuel u want, but if u dont add any more air, ull be worse than stock. so your wrong in thinkin that u can just add more fuel and wham instant power, if it was that way we would all be doing it. wrong forum too BTW
Old Nov 30, 2004
Michalo187's Avatar
Abortion Survivor
I dont mean all the fuel you want just a little more fuel like if i got rsx injectors wouldnt i gain more power because i am adding a little more fuel i know if you add a **** load you will screw yourself over. Right now i saw tunerz on the speed channel they got a stock civic lx put full exhaust,intake, venom control module and venom injectors that add 10% more flow and it helped them a lot the civic went .8 faster than stock
Old Nov 30, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
did you read all the post people posted>???
Like people said your fuel injectors is not even max out yet. So what is the reason getting a bigger one?
What kind of mod you do have on ur car?
Old Nov 30, 2004
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
Venom control module = Crap
Your stock fuel setup can handle an exhaust and a intake, because it won't do much for you on a D motor. 10% larger injectors would be 260cc to 270cc thats smaller then rsx-s injectors and if you were to put 260-270cc in that would be a waste of money there almost the size of stock ones. If you don't want to waste your money buy some bigger injectors and don't put them in untill you have a reason to (aka: turbo).
Old Nov 30, 2004
Michalo187's Avatar
Abortion Survivor
so then why did they replace them on the show? they are professional mechanics?
Old Nov 30, 2004
Jo_Boo's Avatar
Jo_Boo is an unknown quantity at this point
to make people spend money buying them.
Old Nov 30, 2004
Michalo187's Avatar
Abortion Survivor
so then whats a good mod to get now i have aem power pulleys aem cam gear aem v2 intake obx headers custom exhaust venom control module 400 is a flywheel a good mod?
Old Nov 30, 2004
C Orndorff's Avatar
Because 10% is nearly stock size. 10% is just a waste of money, same with a Venom 400. Trust me your stock fuel will handle a exhaust and a intake.
Old Nov 30, 2004
Michalo187's Avatar
Abortion Survivor
the venom actually helps believe it or not well it helped me i dont have vtec
my friend that has vtech says it sucks
Old Nov 30, 2004
C Orndorff's Avatar
A ACT Flywheel and clutch would be a good idea. Particularly if you want to do a turbo soon. Venom 400's suck A long time ago i had one, and it did nothing.
Old Nov 30, 2004
import2nr's Avatar
awd pwnz j00
you took advice off a craptacular show
id hate to see what u learned from F&F
Old Nov 30, 2004
import2nr's Avatar
awd pwnz j00
sorry bro but unless you have a turbo under your hood youre fine with the stock injectors.
Old Nov 30, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
the venom actually helps believe it or not well it helped me i dont have vtech my friend that has vtech says it sucks
Is ur friend vtec a single or dual cam?
if it is a single, it won't much of a difference.
Old Nov 30, 2004
import2nr's Avatar
awd pwnz j00
Lmao ^^
Old Dec 1, 2004
big_daddy_b_99's Avatar
big_daddy_b_99 is an unknown quantity at this point
i hate to ask but did you by any chance get the idea for injectors and and venom 400 from tuner transformation? or it could be a coincidence.
