k20a3 for $700
Old Nov 18, 2004
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
k20a3 for $700
ebay motor and tranny for buy now price of $700, not bad!
ebay link
Old Nov 18, 2004
chicohonda02's Avatar
Since 2002 Baby!
that's cheap
Old Nov 18, 2004
djmota's Avatar
damn they are about the price of a d17
Old Nov 18, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
i just need the tranny
Old Nov 18, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
i bet somethings wrong with it
once you dial that number, they gonna say this and that is all fcked up...
Old Nov 18, 2004
02ciVike's Avatar
02ciVike is an unknown quantity at this point
That is so cheap a3's don't have much of a sales value. Up here they are about 1000-1500 Canadian.
Old Nov 18, 2004
MadWheel's Avatar
Premium Boosted Member
nice find
Old Nov 18, 2004
exclusive_vtec's Avatar
very nice
Old Nov 19, 2004
ArtIntown11's Avatar
The Original F*ckin Angry Armenian
ArtIntown11 has a little shameless behaviour in the past
true a3's dont have much of sales value at all....most people are huntin for a2's or just the JDM a's....::sigh:: if i had a k20a in my sedan oooooooooh i would be the sleeper of sleepers.....so let me as you guys a question, you think it would be worth the money to swap a k20a3 into our civics? would it cost significantly less? Also when you swap and change axles around that means your front axles are going to be 5 lug while your rears are 4? that might be a problem!
Old Nov 19, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
you can alway use the si axle (02-03). They are the same pattern as our civic.
Old Nov 19, 2004
HyaBoosta's Avatar
yeah I live out by the seller. I jut emailed him about the engine if it's legit I might go pick up.
Old Nov 19, 2004
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
If i'm not mistaken, isn't the only difference between the a2 and the a3 is the variable valve timing on the exhaust cam shaft? And isn't that resolved by swapping the a3 head to the a2 head? If that's the case then yes the a3 would make for a inexpensive swap in which later you would have to go back and do the a2 swap and maybe some computer/wiring work. But for punch and go on a budget it makes perfect sense.
Old Nov 19, 2004
^^^^^^ oh ok good that actually cleared a lot up because i dont know if i want to throw 4000 G's for a2 parts when i can put only 2000 in for a3 swap parts. Also how well does the a3 respond to bolt ones....since the a2 does EXTREMELY WELL that would be my entire basis for getting it, it is a great n/a engine, does the a3 respond well to bolts on enough to say it would give ti significant hp gains?
Old Nov 19, 2004
PrecisnTec's Avatar
If it were me, I would be satisfied with getting a stock k20a3 motor in my car. As far as bolt-ons, do your basic intake/header/exhaust and save your pennies for a2 head and ecu and w/e else you need to make that work. Then go about your boltons for the a2 (which probably all are the same between the a3/a2 [taking a guess anyway])
Old Nov 19, 2004
oh no dont get me wrong i would be really happy with a a3 with bolt ons im just curious to as what the times would be with a a3....i actually wanna get one over a a2 because its so much cheaper....
Old Nov 20, 2004
do what i did.. buy an a3 then buy a type r head
Old Nov 21, 2004
CanadianSiR's Avatar
CanadianSiR is an unknown quantity at this point
I have the hatch with the a3. It's not bad, but there are a few gripes with it:
low redline of 6800
no vtec kick (sometimes I wonder if there is vtec in it
Otherwise, I find the motor silky smooth in low and mid revs. I plan to have the ecu reprogrammed to raise the redline (hondata), but I'll wait until the warrantee expires. In any case, if you are considering buying an a3, save up some cash on the side so you can upgrade with bolt-ons.
Old Nov 21, 2004
andyman97's Avatar
Turbo Guru
You won't make the same power by bolting a type s head onto an si shortblock. The type s uses higher compression. If I were to do the swap, I'd go with an si motor and boost it. Then later on, I'd upgrade the head.
Old Nov 21, 2004
hell with just swappin heads damn it im gonna go full type S.....Type R but too complicated and $$ for me
SammySC
121
Apr 7, 2017 07:43 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
