golden eagle fuel rail
Old Nov 15, 2004
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
fuel rail
-Precision CNC machined from 6061T6 billet aluminum
11/16” ( .6875 ) fuel bore for maximum fuel delivery on street or full race alcohol burning engines
- -8AN O-ring ( Boss ) ports provide huge flow capability
-Utilizes two ( 2 ) 1/8 NPT ( pipe ) ports for fuel pressure gauge or fuel pressure sending unit. Also comes with two
( 2 ) 1/8” NPT plugs
-Allows use of stock fuel pressure regulator
Comes with stock Banjo fitting adapter and plug for “bolt-on” applications
-Optional fittings:
- -6 AN fitting Part# GAN100-6
- -8 AN fitting Part# GAN100-8
- -10 AN fitting Part# GAN100-10
GFR105
GFR105-B
GFR105-T
GFR105-P
HONDA CIVIC 2002 - 2004
Found this on the Golden Eagel website. If this is true this is good news for us. I gont know what the different part numbers are for but will try and find out.
link- http://www.goldeneaglemfg.com/street.html ----click on fuel rails
Old Nov 15, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
I think that is for the SI because it doesnt show that it fits 2001. Remember there was no SI in 2001.
Old Nov 15, 2004
audioefx3's Avatar
damm your right just talked to them its for the 2002-2004 civic si
Old Nov 15, 2004
opto_isolator's Avatar
It may still fit if two of the three bolt holes line up....I'm not sure since I don't have one. The only other thing would be clearance for the TPS....
7thgensurvivor
33
Sep 5, 2015 08:20 PM
Damn HeadGasket
Aug 23, 2015 05:27 PM
GritzNGravy
Aug 19, 2015 03:03 AM
martinsmartin
Aug 15, 2015 07:34 PM
Green02civic
Jul 27, 2015 10:48 PM
