Who's up for some injector math?
Old Nov 10, 2004
dezod's Avatar
7thgen Power Maker
In light of numerous injector and fuel pm's I have received, I feel this post would be great FYI and should entertain most of the Q's I receive...
HP / Number of Injectors x Brake Specific Fuel Consumption (BSFC) / Duty Cycle
(For a naturally aspirated engine, BSFC is typically. 50. Competition engines with high volumetric efficiency should use a BSFC of .45, while forced induction engines should use a figure of .65.)
Let's say we have a 200 WHP Civic/ 4 injectors x .65 (FI engine) / .85 duty cycle
200 / 4 = 50 ---> 50 * .65 BSFC = 32.75 ---> 32.75 / .85 duty cycle = 38.53
This means you need a 39 lb/hr injector to support that type of power.
38.53 * 10.2 (to convert to CC's) 393 CC injectors
To convert lbs/hr to cc's, multiply by 10.2. To convert cc's to lbs/hr, divide by 10.2.
Feel free to ask Q's and/or comment. Also, if you learned from this and leave some rep points. undefined
Old Nov 10, 2004
jyoung's Avatar
jyoung is an unknown quantity at this point
i did learn from that, but now it just makes me wonder what happens to engines with to large of injectors compared too it's potential horsepower.
Old Nov 10, 2004
dezod's Avatar
7thgen Power Maker
too large of injectors create unstable idles, possibly too rich fuel conditions based upon duty cycle and fuel pressure.....
Old Nov 10, 2004
jyoung's Avatar
ah, and too small of injectors i guess would just run really lean (especially in a forced induction situation)? whats the effects of running too rich/too lean? trying to suck up your knowledge while i can heh.
Old Nov 10, 2004
dezod's Avatar
7thgen Power Maker
too rich, the car swims in fuel....poor fuel economy, can lead to fouled plugs, carb/soot deposits in exhaust components, drives a little sluggish, can have higher EGT's too.
too lean, the car starves for fuel.....better fuel economy, more power, less reliability, higher EGT's which can lead to warps, cracks, burns in engine internals due to intense heat.
Must be a good balance....Stoich in Vac, Rich under boost (12.5:1 is the most common ratio)
Old Nov 10, 2004
tfnaaf's Avatar
BLDNPSI Mod
nice info dezod, so where do the rxs injectors fall into this?
Old Nov 10, 2004
dezod's Avatar
7thgen Power Maker
They run circa 330 CC
Old Nov 10, 2004
gass03ex's Avatar
gass03ex is an unknown quantity at this point
14.7:1 is the perfect ratio for air to fuel.
Old Nov 10, 2004
sitinduk's Avatar
sitinduk is an unknown quantity at this point
If u work the other way around, can u use injector CC to determine the approx. whp the injectors will support?
Stock injectors flow 240 CC, and use 80% duty cycle right?
whp = #injectors * 1/bsfc * duty cycle * 1/10.2 * injector CC
NA engine whp = 4 injectors * 1/.5 * .8 * 1/10.2 * 240 = 150.588
FI engine whp = 4 injectors * 1/.65 * .8 * 1/10.2 * 240 = 115.837
So u have to increase fuel pressure to make more hp on FI engine.
Old Nov 10, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Well, you have to increase fuel pressure on FI, in order to keep the injector working correctly, as they work off of pressure differential. Say you run 43.5psi base fuel pressure, and are running 20psi of boost. Now, you have 20psi on the manifold side of the injector, and 43.5psi on the fuel rail side, so only 23.5psi of "pressure." You should to increase fuel pressure 1:1 generally with boost, to keep the injectors consistant.
Old Nov 11, 2004
BIG's Avatar
BIG
for N/A yes, but for FI 12.5:1 is the best....
Old Nov 11, 2004
dezod's Avatar
7thgen Power Maker
FI requires far more fuel in the ratio because of the increased air flow.
Old Nov 11, 2004
Havok2k1's Avatar
Wicked Pissah Admin
I agree........ better safe than sorry.......
Old Nov 11, 2004
jyoung's Avatar
ok dezod, lil off the thread topic, but why you are spilling some knowledge, i'm curious about this torque converter i hear of. i guess autos have them and in fourth gear when i'm cruising on the highway it locks up. i know when it locks up i cant accelerate as quickly, but what is it even doing? and why do people talk about getting a torque converter when installing turbos, are their higher grade ones that offer more benefits for a a/t?
Old Nov 11, 2004
dezod's Avatar
7thgen Power Maker
TC are a questionable subject when it comes to turbos.....some people feel it is a worthy investment....others not.
Read this:
http://www.howstuffworks.com/torque-converter.htm
After further insight into it, make the decision on your own.
Old Nov 15, 2004
dezod's Avatar
7thgen Power Maker
up!!!!!!!
Old Nov 15, 2004
opto_isolator's Avatar
Unless you are running a stock block. 11.5-10.5 is an excellent conservative tune. There is a lot less of a chance to fry your ring lands with these numbers rather than 12.5....
But - you're right, 12.5 is almost spot on. The only problem is - the ECU is a bitch to tune because it will attempt to compensate for changes....That's why its better to tune a little more conservative if you can (unless you want a pure track car and don't care about the reliability of the motor).
Old Feb 21, 2005
dezod's Avatar
7thgen Power Maker
Bump For Some Good Info!
runawaykinms
15
Mar 22, 2019 10:32 AM
Dave Brabant
Sep 27, 2015 09:43 PM
Luluharp
Sep 27, 2015 11:56 AM
Bruce2
Sep 21, 2015 08:01 PM
Donahue
Sep 9, 2015 05:55 PM
