boost guage
Old Nov 7, 2004
nightrydin247's Avatar
nightrydin247 is an unknown quantity at this point
boost guage
somebody please walk me through the install on the autometer sport comp boost guage for our car. ive searched for a DIY but i cant find one, so any of the turbo guys who have already done this please let me know. I am plastic molding a single guage pod to the guage cluster, it should look nice once im done. ill post pics of my entire setup once i get this guage installed and the car off the dyno monday night. thanks holla at ya boi'
Old Nov 8, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
Just find a power source for the lights.(I tapped the guage cluster wire) Ground the other side, then run a line from the vacume on the engine to the guage.
Old Nov 8, 2004
yeah but which vacuum source did you use???
Old Nov 8, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
My recommendation is to buy a vacuum block (also called a vacuum manifold). Golden Eagle makes a nice one, and you can get cheaper ones elsewhere. Then, you tap the brake booster line off of the manifold with a T fitting, and run a vacuum line to the block, and then from there, a line to the boost gauge.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
bowie
Jan 21, 2018 09:29 PM
Munzy
21
Oct 7, 2015 07:48 AM
C-Hamm
Sep 28, 2015 10:31 PM
Dave Brabant
Sep 10, 2015 06:48 PM
