Where is good place to run nitrous line thru firewall?
Old Oct 29, 2004
sitinduk's Avatar
sitinduk is an unknown quantity at this point
I'm running my nitrous line from the bottle in the trunk down the passenger side. Any1 know of a good place to go thru the firewall? Is there an existing hole that can be used?
I was thinking about using a hole where electrical wires go thru. It is located just to the right (passenger side) of the center console, under the rug.
Old Oct 29, 2004
HyaBoosta's Avatar
I just ran mine thru the panneling on the floor boards on the drivers side and thru the hole in the forewall right by the clutch pedal.
Old Oct 29, 2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
on the passenger side theres an existing hole as well
Old Oct 29, 2004
sitinduk's Avatar
Can u guys describe the holes u used in a little more detail. I'm having trouble locating them. Pictures would be great.
Thanks for your help.
Old Oct 29, 2004
On the passenger side, kinda up and under the dash board, on the firewall theres an existing hole that is sealed with like a big molded rubber grommet. You have to pull the carpet down to see it if my memory serves me correctly. There is already a bundle of wires running through it. I busted a hole through the rubber grommet with a screw driver. It will be closer to the center console than to the passenger door, but its on the passenger side.
SoyerOner
May 11, 2015 09:46 PM
LikeWh0a
Nov 27, 2001 04:24 PM
ACEM2
Bolt-on Engine Performance
Nov 11, 2001 08:36 PM
wawacito
Nov 5, 2001 03:32 PM
wsking77
Aug 30, 2001 12:32 PM
