Displacement????
Old Oct 27, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
Displacement????
is it me or does the search suck... u type in something and get a biliion other useless items...lol.. i even tried typing "DIY" and it said no results found... shesh oh wells what i was wondering is there someone or something or someplace that can increase displacement in our engines..??
Old Oct 27, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
new rods ... longer stroke ... or boring the block
Old Oct 27, 2004
oh.. lol... i knew that.. i guess i should have been more specific... lol.. but what products and stuff.. u know what i mean
Old Oct 27, 2004
Spider883's Avatar
9K Redline Owns U
engine swap... there is no stroker kit for the D17 unless you go full custom which is a waste of time..remember.. there is no replacement for displacement
Old Oct 27, 2004
dezod's Avatar
7thgen Power Maker
This phrase is almost true except for the fact of forced induction. It kinda levels the playing field a bit.
Displacement can be increased as Asnsurfer said......increase bore or rod stroke. Only ways other than a swap.
Old Oct 27, 2004
takumi's Avatar
takumi is on a distinguished road
Ya, the search engine usually doesn't work too well for me.
Old Oct 28, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
No, the phrase is true. A larger displacement engine will make more power all other things being equal.
Old Oct 28, 2004
dezod's Avatar
7thgen Power Maker
The concept with everything equal, is true, your right. With the displacement of a 5.0L Mustang, the displacement is much more than a Civic without a question, correct? Then with the addition of forced induction (turbo or supercharger) the Civic can now beat the 5.0L Mustang. Reasons behind this: significantly less weight and the addition of forced inducrion. This is how a local kid has an 11.2 second 1/4 mile CRX. The addition of forced induction with weight reduction levels the playing field of displacement. So the phrase holds validity....I was never denying that. Merely stating the concept is close minded and there are exceptions to it.
Old Oct 28, 2004
There are no exceptions to the all things being equal, the larger displacement will make more power. It's simple fluid dynamics. I'm not refering to wether or not a 5.0 mustang can be a turbo honda, I'm talking about 2 identical engines with different displacements.
I'm working in theory. You're working in application. :-)
Old Oct 28, 2004
dezod's Avatar
7thgen Power Maker
Exactly. Theories........they all sound nice until application, which really proves or disproves it.
Old Oct 28, 2004
Yea it is a proven theory, so technically it is "fact." A larger motor WILL make more power, but when you have a shitty big motor vs an efficient small motor it levels the playing field.
Old Oct 28, 2004
dezod's Avatar
7thgen Power Maker
Old Oct 28, 2004
ExospeedRacing's Avatar
ExospeedRacing is an unknown quantity at this point
You can increase displacement on the D17 by doing 2 things.
Either by stroking the motor or going big bore on the sleeves. I dont recommend the stroking method really since it deals with so much more custom parts and that means more money. A stroker setup will need a custom crank, custom rods and possibly custom pistons. That alone will set you back close to $1500-2000 and thats not even touching the block yet. And also, since they are custom parts, if somethign happens, its harder to replace the parts and cost more if they do.
The other choice is sleeving the block. We do big bore sleeves all the time for the D,B, H, K and F series blocks. On a d-series, we usually go 2mm bore bigger than stock to increase displacement, for forced induction applications.
BUT: As much as I'd like to think bigger is better, its not necesarrily the best way to go. We have built 600HP B-series motors on the stock 81mm bore. The block is sleeved, but we keep it at 81mm still. When you are going turbo, concentrate more on the fuel management,etc rather than the bore size. We already know we can make power without going big bore.
Old Oct 28, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Chek what the fraise sais "There no replacement for displacement", yes there is that forced induction, that why you could have an Audi A4 with a 1.8t I4 or a 3.0 V6, they may not have the same power, but you could raise the power on the 1.8lt and none would be the waiser, that the advantage of a turbo or supercharger, you could add HP's without increaign displacement........
Old Oct 28, 2004
Ever seen a turbo big block vs turbo honda?
There. Best of both worlds. Hows 2000+ hp sound? Ever do that in a 1.8L?
Old Oct 28, 2004
dezod's Avatar
7thgen Power Maker
Actually all the HP in the world does not matter if the power can't be kept and distributed to the ground. I have seen some big block boosters myself...
Old Oct 28, 2004
opto_isolator's Avatar
Meh - nothing but brute force....
I'll take my elegance and engeering over brute force anyday
Old Oct 28, 2004
dezod's Avatar
7thgen Power Maker
Well put Opto.
Old Oct 28, 2004
That is elegance and engineering. This is brute force:
Old Oct 28, 2004
drjvic04's Avatar
drjvic04 is on a distinguished road
F1 cars are putting out 100hp for every .1 liter of displacement. More efficent right. So that 1.8l theoretically could be at 1800hp.
There is a replacement for displacement. Forced induction be thy name.
Old Oct 28, 2004
civicskater's Avatar
Chicks dig my scent
Big blocks are made to make huge power...thats why they're made. Huge displacement=huge power, you put forced induction on that of course you're making more power. I like the harder things in life...anyone can make a big *** motor push 500whp, but getting a 2.0L to make that much horsepower, and being able to control it ie: put it to the ground when and where it should be...thats power, not power of the motor, power of the builder...ie: elegance and engineering in my opinion
Old Oct 28, 2004
nindoo's Avatar
Why is my vagina bleeding?
F1 would be even sicker but they have put a limit on HP(Still disgustingly fast). You know abou the tracks being modded for safety purposes.
Old Oct 28, 2004
You also have to realize what kind of RPM an F1 motor spins in order to make that horsepower. The torque is ~250 ft/lb.
jpandjf
Aug 3, 2015 05:02 PM
ballmich
Jul 9, 2015 11:59 AM
S2000man01
Sep 29, 2008 04:08 PM
APME123
Dec 11, 2003 11:52 PM
n00dleboy
Jan 29, 2003 10:31 PM
