Stock Injectors
Old Oct 20, 2004
chesireCAT's Avatar
chesireCAT is an unknown quantity at this point
Stock Injectors
Just out of curiousity
I have been running a return fuel system, aeromotive adjustable fuel reg., walbro 255 fuel pump, stock injectors, and emanage to control it all. (having trouble controlling to some extent though) and I installed it all
Anyhow, I hit 6 psi in 3rd at full throttle and I stay in full green on the a/f (not a wb02 though) and it pulls hard (t3/t4b)....seems the stock injectors are fine for now....
anyone else have similar results?
where is the most common place to get the rsx injectors? I would like to run 8-10 psi
Brandon
Old Oct 20, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
just curious, but how's the narrowband A/F? I wanna get a/f gauge for my soon to be setup, but i don't wanna spend the extra big bucks for a wideband
Old Oct 20, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Narrowband is not accurate enough for tuning.
Old Oct 20, 2004
chesireCAT's Avatar
put a down payment on a wb02
the guage is nice to let you know what is generally going on but a palm pilot and a wideband is very very nice, much much much more accurate
Brandon
Old Oct 20, 2004
The innovate LM-1 is only $350. It's pretty cheap for what it can do, especially down the road if you get any of the data aquisition boxes for it.
Old Oct 20, 2004
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
ive seen stock injectors go ATLEAST double hp.... tuned right even higher.. good luck.. im @ 9psi, ported head, etc... stock injectors ...
Old Oct 20, 2004
Boosting Daily
But is it good enough to just know if you're running too lean or too rich? I'm getting a simple kit that i don't think would need EXTENSIVE tuning since i'm only gonna be running a very mild 6lbs of boost
Old Oct 21, 2004
opto_isolator's Avatar
Yeah!! Lets spread more bullshit rumors on the forums that stock injectors can handle boost!!
The stock honda injectors are only good for what little power the car makes stock. The ONLY reason that YOU are able to make more pwer on your setup is because you are running an insane amount of fuel pressure to force more fuel through them than was intended.
Honda's injectors are fairly close to their max duty cycle at WOT stock. Hell, my RSX injectors read somewhere around 70% duty cycle at 8 pounds of boost....
Keep boosting on those injectors with no wideband CT and eventually you're going to fry your ringlands....
Old Oct 21, 2004
HyaBoosta's Avatar
^^^Werd!
Old Oct 21, 2004
gotti's Avatar
i fried my ringlands
Old Oct 22, 2004
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
what is best place to get urself some RSX injectors? Go to Acura dealer? Or can you order them through a shop?
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
Jul 12, 2015 11:54 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
