VTEC engagement and Turbo
I got a crazy PM from a honda service guy. I will leave out the name to protect the inocent. I have a VAFC2 and know when my VTEC kicks in. The guy views the boards. Can others who have VAFC2 explain to this guy that vtec engages at 3K on the D17. He has sent me 3pm's telling me I dont know **** and that all VTEC kicks at 4.5k and that I must be smoking crack or something.
Also if I am wrong please correct me so I dont look like a complete ***. But I know I am right. So flame if you would like. No sweat. My D17 is in parts anyways.
Also not too be an a know it all or anything. I dont think I have heard anything right from a honda authorized person yet. When I bought my EX I was told it was the same engine as the base RSX. I am sorry most people at the dealer probably cant change their own oil.
.No you do not know what you are talking about. I work in a Honda parts department so I think I know a ting or two. First Off what I am about to say is directly from a Honda tech manual for D series engines equip with v-tec.
First off you cannot hit vtec at 2500 RPM because your engine is making only about 35 of oil psi.
Second you have to have 100% Throttle because 50% throttle only sends 3 volts.
The only reason you are hitting vtec at 2500 is because you set your VAFCII to that RPM. Your VAFCII is a type of ECU hack that bypasses the ECU and sends a 12-volt signal directly to the vtec solenoid.
Also for your sake you should not hit vtec at such low RPM’s it is bad for your motor to be in vtec without the proper oil psi, this is why Honda puts a 4500 minimum into every ECU. They did it for a reason.
Normal v-tec engagement happens from 5200-5500 on any Honda.
If you don’t believe me, go pick up a Honda service manual yourself or ask a Honda tech. While I wrote this I talked with one of my buddies that is a Certified Honda Tech and he verified every figure.
7thgen Power Maker
Hate to say it, but the guy is right.
Originally Posted by gearbox
Do you believe him or the ecu? Stock vtec engagement as output by the ecu. I have not tuned my controler yet.
Like someone else also said. Ask the guys who have done the DIY vtec light. VTEC kicks in at 3k.
Damn Dezod you should know this already. I guess emanage does not have a vtec light.
Originally Posted by HyaBoosta
Is it the same engaugement point on B serise engines too?
Turbos, Engines, Chassis and Suspension Tech
Properly configured, the VTEC transition point will not be evident, even in a B series. The only exception is in large cams that have a significant difference in lobe size. Most hondas have different VTEC activation points as the motor configuration is different.
Mr. Honda Parts Guy, I recommend you learn how to correctly express your feelings towards guns using proper english, because all it does is make you look like an idiot.
Ok, a "ting" is not a word. "Thing," on the other hand, is. And if you work at a honda dealership, why do you mistype VTEC? It's not v-tec.
yup... hook up a vtec light to your vtec solenoid. Depending on throttle pressure, it kicks in earlier or later ... (~2200 for hard throttle, ~3400 or so on very light throttle) ... and vtec is ALWAYS on past about 67 mph ... which would equate to about 3400 rpms (in 5th)
7thgen Power Maker
Several criteria have to be met for VTEC to engage, it is not just RPM dependent as many of you claim.
I have personally read some of the service manuals for various years of Hondas. This is regardless of your DYI VTEC light, which I do not feel is THAT accurate. Take a Honda ECU onboard diagnostics machine into the car and go for a drive and let it data log. That machine will tell you if the ECU signals for VTEC engagement, it may signal at 3000 rpms or so, but it may not kick in because of other parameters not being met...load, rpm, oil pressure.....Reason why I know this is because it happened to me when I was trying to configure the E-Manage for VTEC controlling, but it did not engage at all.
Engagement is at 3k rpms. Now if the engine is cold, I've heard it won't switch to hi cam mode. It can also be variable, depending on the throttle position and/or rpms. And if you have a 6th gen D series, the vtec can be heard as a kind of whistle/supercharger sound around 3k if you hold it in gear above that rpm. They eliminated this on our cars as supposedly making it better. So now you don't hear anything.
^^ my friend has a 99ex and his vtec engages at 5500 rpms ... according to his vtec light (you can hear it as well ... YES YOU CAN HEAR IT). fyi, d16z6 and d16y8 vtec is 3 lobe vtec, which is why you can (slightly) hear it. by NO means is it anywhere close to as loud as b16's, etc ... but it is definitely audible while driving.
dezod: why do you think a vtec light is inaccurate? ... when the vtec solenoid gets a signal, it activates vtec, true? I don't see why vtec lights are inaccurate at all
Why is my vagina bleeding?
Yeah I actually notice an electric motor sound from 1-4k rpms. After that, the engine sound changes.
The hi vtec engagement you guys are thinking of is for the 99-00 SI DOHC. My friend has a 99ex and vtec switches around 3k.
Once boosted now i-VTEC
I am the Honda guy Guns is talking about and he totally changed my words around in his quote. Also I did not come out of nowhere and start yelling at him about v-tec he started it almost two weeks ago. This is what I said.
“What I am about to say is directly from a Honda tech manual for D series engines equip with v-tec.
The following things have to happen for v-tec to engage on a STOCK (not VAFCII equip motor) D motor.
1 Your MAP (Manifold Absolute Pressure) sensor must read 0hg (aka 0 inches of vacuum). When it reads this it will send a 3volt signal to the ECU.
2. Your throttle has to be open 100% because your TPS sensor has to send a 4.5-volt signal to the ECU.
3. Your coolant temp has to be at running temp.
4. Vehicle speed has to be above 20mph.
5. You have to have 65-80 oil psi.
6. The engine must be running at a minimum of 4500 RPM
When all of this happens your ECU sends a 12-volt signal to your v-tec solenoid that activates your 4 lock Motion assembly’s (or if you have DOHC 8 LMA’s because SOHC has vtec on the intake only)
First off you cannot hit v-tec at 2500 RPM because your engine is making only about 35 of oil psi.
The only reason you are hitting vtec at 2500 is because you set your VAFCII is set to that RPM. Your VAFCII is a type of ECU hack that bypasses the ECU and sends a 12-volt signal directly to the v-tec solenoid.
If you don’t believe me, go pick up a Honda service manual yourself or ask a Honda tech. While I wrote this I talked with one of my buddies that is a Certified Honda Tech and he verified every figure.”
So you have to have the throttle fully open for it to engage? That means my vtec has only switched a few times in the three years I've driven the car. I don't buy that. I still see a signal being sent. I DO have a service manual. Some Honda techs don't even know what a timing belt is.
vtec can crossover at any rpm ... look at the 02 Siit can crossover at ANY throttle. How? get in a b16, b18c powered anything and get up to a certain rpm, typically around 5500-6000 depending on the car, you'll see ... you can HEAR it and FEEL it
depending on throttle pressure, the engagement rpm may change, but it still crosses over under a given rpm
You guys talking about the B series... you do know that most of those motors also have secondary intake runners, right? Those butterflies do not have to have anything but RPM and throttle % to engage, and the RPM point is lower than VTEC engagement. That's what you're hearing with the whistling sound.
