Emanage set up for rsx inj. on N/A
Old Oct 10, 2004
HyaBoosta's Avatar
hey I wanted to do the emanage install and install my rsx injectors so the shop that installs my boost won't run into any problems. can anayone give me some base settings or options so i can just do the install on the injectors and emanage. Oh and is it possible to tap in the wires just to make sure it works then soder them?
Old Oct 10, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Be careful when you install it, cutting and splicing ECU wires can have a bad consequences if you don't know what you're doing. If you've never installed electronics like this before, please take it to a professional. Yes, you can run the RSX injectors NA, all you do is set the base correction for them in the parameters of the emanage. You may have to do a little correction, but nothing major. I do not believe at this time that the VTEC control function of the emanage works with the 2001+ civic ecu, I've been working on the issue and will get back to everyone as soon as I can.
Old Oct 11, 2004
HyaBoosta's Avatar
i've done some work with installs of this nature, But I am going to play it safe and tap all the wires firs and make sure the install goes smooth then I'll start sodering.It's not going to run the rsx injectors Na for good. just want to make sure that the emanage and injectors get installed right since our year civics are a little different and not many shops have thrown boost on them yet.
Old Oct 11, 2004
You should have no problem with the RSX injectors NA at all.
Old Oct 11, 2004
HyaBoosta's Avatar
would they be fine if they were installed without the emanage or would that just make the mixture too rich? and do you think all the connections will be fine for a test if I tap all the wires to the ecu?
Old Oct 11, 2004
The injectors will make the car run very rich if you don't have any way reduce the amount of time they are open. The emanage would need to be installed before the injectors go in. You can tap the wires to check, that shouldn't be a problem.
Old Oct 11, 2004
HyaBoosta's Avatar
Im going to do the install this weekend then and see how it runs.
GolNat
Nov 27, 2018 03:32 PM
JMKendrick
Sep 16, 2015 06:17 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
