People with Return Fuel Conversions
Old Oct 6, 2004
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
I was just curious what psi fuel pressure different people were running at different boost pressures. If you could, list if you are running stock injectors or not. Anyone know the stock returnless fuel pressure off hand?
Old Oct 6, 2004
opto_isolator's Avatar
Stock pressure is around 45 PSI. I run about 48-50 PSI with my RSX injectors at idle.....
Old Oct 6, 2004
Drk01Civic's Avatar
Awesome Opto. Thanks for the reply. Does anyone know if our ECU senses fuel pressure and if it will change it or reduce injector pulse width because of a change in pressure. I'm guessing not because I haven't seen any threads on this board about that but I think the Ford Focus does it. I need to buy a Helms manual or something.
Old Oct 9, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
im about the samne as opto
CarStuff
Dec 6, 2020 12:52 PM
Wild Cranker
427
Jan 28, 2016 06:49 PM
Broadbeb
May 14, 2015 09:49 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
supercivic01
South
Nov 30, 2001 11:27 AM
