14psi on stock internals w/stacked headgaskets.
I want to get an awsome dyno now that I have my complete setup minus built block. So today I put in 2 stacked leakless head gaskets and torqued down the headbolts to 52lbs. The purpose for the stacked headgasket is to lower compression a little so I could up the boost. I ran around tonight at 14psi and no problems. I pulled the thermostat to keep it in the cool range and ran it rich with alot of methanol. I did compression test afterwards and it was good as new. Headgasket held fine.
Be sure to check back for an awsome dyno. I will run it at 14psi and be sure to take plenty of pics and maybe a short video clip. Soon to be the highest whp on stockinternals with dyno proof. Catalyst claims 300+whp but has no dyno proof of it.
If anyone is interested this complete kit is forsale.
i have dyno proof, but its mine. I worked my *** of tuning my car, and it was for me, nobody else.
Im sorry if that sounds stupid to you guys, but thats the way it is. And the car will probably never see a boost level that high ever again, so there is really no point.
Anyway, Guns...
Set some new records. Thats the kind of stuff we all love to see. Just dont do something stupid, like run out of methanol.
Anyway, Guns...
so if you lowered the compression to add psi...does that mean that the dx/lx with out the higher compression heads with vtec will be able to hold more psi?
Edit: BTW, I'm not boost saavy, just a beginner that is starting research cause i'm interested in boosting...
Originally Posted by C2i0v0i1C
i got the same damn thing so i know it works, but u pulled the thermostat out why
I checked compression again today. I have a little over 180 even on all cylinders. What are the numbers for others. Just wondering, want to see if how much the stacked headgasket lowered compression.
Originally Posted by someguy
damn....your brave man. i know people running 14-15psi on stock internals...but they will blow one day.
Originally Posted by guns
Did I mention the kit is for sale and I live in H-town.
Pulling the thermostat keeps the car in a open loop, closed loop cycle... Not the best idea.... Might help a *bit*, but long term it's not the best....
OK had some good runs on the dyno. I ran 9-10psi and the 11-12psi. The owner convinced me not to run 14psi do to the fact that my injectors are maxed out. I was runing 14.5 a/f ratio and did not want to chance running lean. Word of advise do not rely on narrow band a/f gauge it should me extremely rich.
IN spite of running lower boost than I wanted I got some good numbers. The top dyno is the two runs and the bottom is a year of work. My base dyno and todays on the same page. It was a hot and humid day so in the winter in a dry climate the numbers should be about 10-15whp better. Texas gulf coast is not ideal conditions to dyno in this time of year. Rained that morning and was extremely humid.
As you can see this kit has great potential, Bigger turbo and piping should yield better numbers. Also I need RSX injectors. Stock injectors dont cut it. Was good at low psi. But up the boost and it gets scary close to lean. Sotck internals held fine and compression tests show my internals after 14months are fine.
Happy Boosting.
Happy Boosting.
what the hell is this break in power ****
is that dyno with the 2 head gaskets
