T3 T4 Turbo question
Old Sep 20, 2004
grddygrl's Avatar
grddygrl is an unknown quantity at this point
Hey peeps! I am putting some boost behind my 03 civics purr and was wondering if anyone out there had some advice on using a T3 T4 turbo. I heard that it doesnt spool up very quick on a civic like mine and that I wont feel and power till close to 5K I was just wondering what you guys thought and if there is a better set up out there that I should be looking at?
Old Sep 20, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
most members here uses T3 Super 60 which full at 3.6rpm. You can get a T25 much faster spool, 2.5 full spool.
Old Sep 21, 2004
vtecd17's Avatar
Desperate Custom Swapper Speed Freak
vtecd17 is an unknown quantity at this point
not as much power wit t25, rec. t28 if u go that route.
Old Sep 21, 2004
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
you want a TD04 my friend!
quick spool 2800-3000 rpm, and upto 18psi or so
Old Sep 21, 2004
pothole's Avatar
pothole is an unknown quantity at this point
I am using a Garrett T3 AR 60 which will spool at 5psi at around 2800 rpms and at 10psi at about 3500. I went with a bigger turbo because later down the line, I want to build the internals and a small TD04 will only handle up to 18psi. Mine handles up to 30psi
Old Sep 21, 2004
grddygrl's Avatar
Thanks for the info got the kit on the way, ready for racing soon!
-HondaFTW-
Aug 30, 2015 10:38 AM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
bhollie
Aug 12, 2015 09:58 PM
justcruzin125
Aug 11, 2015 09:09 PM
